2001 S60 Any preventive maintenance proposal? Topic is solved
This topic is in the MVS Volvo Repair Database » S60 Preventive Maintenance Parts
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
maybe pull the dipstick up for now? good to relieve pressure instead of blowing a cam seal or other place
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
zoli_m13
Year and Model: S60 2001
Post by zoli_m13 »
mika wrote:maybe pull the dipstick up for now? good to relieve pressure instead of blowing a cam seal or other place
Thanks for the idea, Mika!
I tested the PCV system and after some discussion with VOLVO mechanics: it's minor blockage; no excess pressure building up at idling or higher rev's (checked at oil filler tube and the dipstick). Also, no any oil leak around the oil filler tube.
Rather than higher mileage 'disease': the piston rings getting go be worn, so some exhaust gases leaks into the crankcase vent system, can't be sucked fully by the PCV system.
Have a relaxing Swedish weekend! :-) 8)
2001 VOLVO S60 2.0T A/T 245K+ miles
https://goo.gl/photos/jS1z777LDqJSQqPDA
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
New PCV on turbo engine made by Volvo develops a lot of vacuum in crankcase. I bet your PCV is clogged.
vtl
Post by vtl »
zoli_m13 wrote:Do I start to worry about the voltage regulator or the battery or some connection failure around the alternator?
EDIT: battery had 12.2V this morning (before firing, staying for an overnight at 5°C / 41°F) and constant 14.1V measured while the engine was idling around 1000 rev (cold engine). Seems to me OK.
EDIT2: charging of the fully warmed up engine at idling by 14.0V - measured at the battery terminals, a/c was on.
Worn brushes on voltage regulator result in alternator incapable of charging battery at lower engine revs. So if you see voltage warning while engine is idling and don't see it when cruising on highway, that's probably regulator.
Other possibility is faulty electronics draining battery badly. Wife's 2002 V70 had recently a problem with siren module, car threw low voltage error, even it had new alternator and high capacity AGM battery installed 3 years ago. Ended up like that: http://www.volvoxc.com/forums/showthrea ... went-south
Oh, yes, all siren modules will fail like that because of its design and mounting position (leak-prone NiMH battery sits above circuit board).
zoli_m13
Post by zoli_m13 »
Thanks for the comments, vtl!
I saw your battery/siren improvement - looks like a reasonable preventive maintenance item! I like this type of DIY care as well.
zoli_m13
Post by zoli_m13 »
draser wrote:My car had tape wrapped around connectors, and they were pretty clean upon removal of tape. Learned something from Volvo, electrical tape is fine.
Today wrapped the electrical wires (ignition coil and injector) - took only 1 buck. :-)
zoli_m13
Post by zoli_m13 »
We made some fun with my son: checking of disconnected headlight wipers;
- the good news: washers works fine, but the water pressure is not so high
- the connected wiper motors inoperative - sorry to say, but useless design for me. Disconnected again... :cry:
zoli_m13
Post by zoli_m13 »
Some minor improvements of today:
- opened up the old fuel filter (OEM VOLVO): very strong metal house and filter material; no any particles found
- painted the set of steel rims for the winter tyres (used ones with VOLVO hubcaps; it was a bargain)
Some photos:
zoli_m13
Post by zoli_m13 »
Quick and easy DIY for much comfortable travelling for my kids at winter-time: carbon seat heater pads installed under the rear seat bottom. Step-by-step photo series are below without text.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Perfect accessory for the fabric and leather seats you have there! ! Where did you find the seat heaters?
