98 s70 steering wheel locked while driving
Anut808
Year and Model: S70 1998
Post by Anut808 »
the steering wheel suddenly locked up while we were driving. I was able to wiggle the wheel and get it unlocked. any ideas what to check ?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Does the key work properly or does it spin all the way around. The ignition cylinder on the 70 series is a know weak spot. It is a fairly big deal to change it but we have a couple of writeups in the repair database.
Anut808
Post by Anut808 »
The key doesn't spin all the way around. But when you put the key in sometones you have to flip the key around and jiggle the wheel to get it to turn.
Post by Ozark Lee »
If the key is behaving more or less properly then the cylinder is likely OK. Were there any unusual sounds? This is an odd problem which is why I am asking so many questions. There are a few things that could be happening but they are all rare.
The power steering pump could have a problem, I would check the fluid level in the reservoir and also check the line from the reservoir to the pump. The way the hose routes it is possible for it to wear on the power steering pump pulley.
The rack itself could be the problem but its typical problem is that it will spring a leak and there will be puddles of fluid on the ground under the car.
The linkage from the steering wheel to the rack could be binding but that typically gives you quite a bit of warning in that the steering will feel rough.
I'm at a bit of a loss on this one since it is so unusual but it certainly needs to be dealt with.
Anut808
Post by Anut808 »
Well checked the fluid and it was low. Will watch and see if it's leaking. Thanks Lee..
Been thanked: 504 times
Post by cn90 »
Very unusual issue of SW lock during driving. This happens when the rectangular piece somehow goes straight upward, locking the SW.
For safety reason, consider getting rid of this SW lock feature. On a related topic of tumbler issues, when you remove the bottom plate, you remove the SW feature because the spring is removed...
DIY: 1998 S70 GLT Ignition Tumbler FREE Fix!
https://www.matthewsvolvosite.com/forums ... hp?t=67531
