1991 240 What attaches window to regulator?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
s10lowrider1994
Year and Model: 2000 v70
Been thanked: 3 times
Post by s10lowrider1994 »
The passenger window on my 240 is wigging out and I'm trying to figure out what I need to fix it. The regulator works fine, the window simply isn't attached at the bottom like it's supposed to be. I see the channel but don't see anywhere clamps would be like on most cars, it's just a channel. The window will roll up and down, it just has a tendency to come loose on the down swing and releases itself from the channel so I've gotta push it down manually. Basically the channel it sits in pulls itself away from the window when I roll the window down. Are there clamps that are missing? Is it just held in there with glue or pressure? I'm not sure what to look for as the PO has butchered everything possible so I can't tell for sure what is rom isn't supposed to be there in regards to the window mechanism. The car has almost 500 thousand miles so I'm sure something is either worn out, missing or broken, I just don't know what it is. Any ideas?
