1996 Volvo 855 Leak at heater hose coupling
banjoman
- Year and Model: 850, 1996
I installed a new heater core, coupling, O-rings, pipes, and hoses about three months ago. I used the best quality parts available and was careful to install the O-rings in the correct sequence. I just discovered I have a leak inside the car at the lower coupling. I have tried pushing hard on the pipe into the coupling but it does not help. I am aware of the bypass idea to get rid of the coupling but am not ready to do that. Any ideas on how to stop the leak?
- Been thanked: 504 times
@banjo,
Are you using aftermarket O-rings? They are notorious for leaking.
Dealer O-rings are much better.
Anyway, I am glad I did the coupler bypass, nothing to worry about. So far so good (I wrote the bypass DIY in forum).
To me the firewall coupler is bad design, this is why I got rid of it at 167K miles.
Detail below...
https://www.matthewsvolvosite.com/forums ... hp?t=69238
Detail below...
jonesboy1983
- Year and Model: V70 2007
When I replaced the coupler, it had all the o-rings etc. attached inside already. All that was required was to plug the heather hoses into the new coupler. Perhaps your removed the o-rings and plastic spacers from the coupling and that damaged them now causing the leak? Just an idea.
banjoman
The coupler are Volvo and I think the rings came separately and had to be inserted. The leak happens only after you run the car for a while, and then it is a small stream from the lower coupler down the firewall, not huge but enough to require correction.
jonesboy1983
I think that is the problem though. The coupler I got from Volvo did not require adding any additional rings. All you had to do was plug in the heater hoses from one end and the pipes from the other. I remember because I bought the plastic plugs and rings separately and returned them because I never used them when I replaced my heater hoses and heater core.
- Year and Model: Lots
- Been thanked: 128 times
The "I inserted the o rings in the correct sequence" statement also has me worried. You should just simply push in the hoses with a new coupler; nothing more to do.
Was it in a sealed bag?
In case you want to re-assemble the o rings it's rubber-plastic-rubber-plastic-rubber starting from the deepest point.
banjoman
I first ordered just the rings/spacers and inserted those in the old coupler; when that leaked, I ordered a new coupler (all Volvo parts). When I say I inserted the rings/spacers in the correct sequence, I may be thinking of the first failed attempt, and it is probable that I did not bother the rings/spacers in the new coupler and just inserted the metal pipes. The little leak continues. I just loosened the screw holding the metal pipes to the core so I could perhaps push lower pipe further into the coupler; drove it for about 15 minutes, and the little dribble was there.
banjoman
To close this, I removed the coupler and found a broken o-ring. The ring was new when installed three months ago. I noticed the plastic spacer next to the ring had a tiny nib on it; I wonder if that cut into the ring and caused it to fail. I checked the other rings and spacers and found another plastic spacer with a nib and a ring with some excess rubber attached to it. When installing the coupler, I would inspect the rings and spacers to be sure they are in good shape. I put everything back together and ran it for about 30 minutes with no leaks.
- 471 Views
Last post by JimBee
- 352 Views
Last post by erikv11
- 1075 Views
Last post by banjoman
- 1254 Views
- 23 Replies
- 6699 Views
Last post by callahanoffroad
