DIY: 1998 Volvo S70 GLT Heater Core, Heater Hoses Rebuild!
This topic is in the MVS Volvo Repair Database » DIY: 1998 Volvo S70 GLT Heater Core, Heater Hoses
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
In the thread below, songzunhuang discussed replacing the two (2) heater hoses etc., only to realize that it is much better to get rid of the whole thing (O-rings, firewall coupler etc. etc.) and simplified the system by using this approach: Heater Core ---> Cut Pipes ---> Generic Heater Hoses ---> Gutted Coupler ---> Re-used the barb fittings ---> Generic Heater Hoses ---> Engine:
https://www.matthewsvolvosite.com/forums ... hp?t=67217
Make sure you read through the entire thread above.
Another good thread by rspi:
https://www.matthewsvolvosite.com/forums ... hp?t=58733
-Anyway, this is my experience with ebay Heater Core ($40 incl. shipping), and used standard heater hoses to simplify this whole convoluted Volvo setup.
-This is strictly preventive maintenance at 167K. The cabin once in while has this very faint sweet smell. The car consumes two (2) cups of coolant every 5K or so (going from Max to Min).
Since others have reported the heater hoses can burst, dumping coolant in a matter of seconds and since the heater hoses are 18 years/167K old, it is time to replace them on a preventive basis. This is one job you do NOT want to do in the middle of nowhere, trust me.
- Budget 4-6h for this whole project.
PARTS:
- Ebay Heater Core ($40) Do NOT use the two (2) O-rings that come with the ebay heater core: when cold they are OK but when you drive the car, the system is pressurized, they will seep a bit. Best is to buy two (2) Volvo OEM O-ring (PN 3545586), about $3-$4/each.
- Others mentioned the ebay heater core can smell. So I boiled some water, added some DW detergent, then dipped the HC in there to clean all the grease (I removed the foam for this process, maybe unnecessary step), then rinse with water. You can put the HC in the DW but it takes a long time for the whole 2-3h cycle.
- Standard 5/8-inch heater hose. I used Gates brand (someone told me Gates is better than Thermoid brand), 6 feet is bare bone minimum. I bought 8 feet just in case, it is about $1.50-$2.00/ft at Napa auto parts. In contrast, if you buy Volvo OEM heater hoses, they are about $60/each!
- Six (6) clamps for the project: 2 inside the cabin, and 4 at the firewall area.
- Prestone coolant and distilled water.
TOOLS:
- Torx keys
- Screwdrivers
- Pair of pliers
- Angle Grinder or Dremel tool to remove factory crimp in order to re-use the barb fittings.
Wear goggles when operating Angle Grinder or Dremel tool!!!
- Butyl Rope (stuff used seal vapor berrier or older windshield glass, buy it at local auto glass store), this stuff is used to seal the firewall coupler/generic heater hose space. Or you can use your favorite caulking stuff, as long as it can handle engine heat.
- Latex gloves: there are a lot of sharp edges to deal with!
PROCEDURE:
1. D/C battery cables and remove battery from car. Make sure you have code for the radio.
2. Drain coolant: I drained it from LOWER rad hose (avoid using the radiator petcock!). If coolant is new, then drain it into a clean container to re-use it. You may need a funnel/coffe filter paper to filter out debris before putting it back into the reservoir.
3. D/C MAF connector and air intake tubing etc. Then d/c the LOWER rad hose from the engine. You will see that the two (2) heater hoses connect as follows:
- The UPPER heater hose to the Front part.
- The LOWER heater hose connects to the area under the bigger pipe (that connects to the LOWER rad hose). When in doubt, feel around using your hands.
4. Note that the heater hoses use an unusual type of clamps: 7-mm socket or wrench is the key!
5. In order to minimize spill inside cabin:
- I used a funnel to the UPPER heater hose, added some water so it runs clean.
- Then used a separate tubing, attach it to the UP PER heater hose, then blew through it until no more water comes out.
- Once I d/c the heater core pipes, very little clean water came out.
6. To d/c the heater hoses from the firewall coupler, squeeze the yellow clips then ROTATE the pipes, then pull it out. The coupler is held by two (2) Torx 15 screws.
7. Old heater hoses not too bad at 167K, but they are on borrowed time:
8. Once you cut and remove the crimp, one side (with the edge) goes to the engine and the other goes to cabin. However, if you reverse it, it is fine too. Inside the cabin, cut the pipes as shown below, then make sure you have heater hose long enough to:
a. Cover the pipes by about 2-3 inches to avoid leak.
b. Stick out of the firewall by about 1.5 inches.
9. Old heater core with 167K: not too bad, but you can see where the coolant leaked out and dry residue left behind.
10. Inside the cabin:
a. Remove the gas pedal (slide the pivot pin to the LEFT), then undo the 10-mm bolts to remove the gas pedal base.
b. Undo the Torx 25 bolt that holds the pipes to the heater core, then d/c the pipes. Photo shows pipes cut ready for re-assembly.
11. The heater core DIY is covered in the video by rspi above. On each side, you need to remove the 2 screws as shown (T15 and T25).
12. Next photo shows you the gutted coupler: no need for any special tool, use a pair of cutting pliers and remove the inner core, very easy, it slides right out. The holes left behind are just a tiny bit bigger than the O.D. of the 5/8-inch heater hose. Then cover the gap with caulking stuff. I used Butyl Rope. BEST is to install the gutted coupler first, then slide the heater hoses through. Connect all the clamps etc. Once everything is good, then apply Butyl Rope to both inside and outside areas to prevent fume from entering the cabin.
13. Final photo before filling up with coolant. Note that the AC drain must be re-connected to the floor drain.
14. Fill system with the correct amount of coolant. Since I flushed the system with distilled water to get rid of old coolant, and since coolant capacity is 7L for turbo (~7.2L for non-turbo), I added 3.5L of pure Prestone coolant to ensure I have the 50-50 mix for my winter months. Once I added 3.5L of pure Prestone, I only used distilled water afterwards.
- Drive the car around the blocks, don’t go too far (if you do, carry extra distilled water in the trunk!), chances are you will need to top up with more water (or coolant) twice. Make sure th engine is cooled down before opening the cap.
This is your chance to get rid of the convoluted Volvo design with a gazillion of O-rings, yellow clips, this clip that clip, this O-ring that O-ring etc. It is a bullet-proof system when you do it this way! Use only quality heater hose (Gates) or silicone hoses.
That is all boys and girl…
PS: The ebay heater core is as hot as the Volvo OEM heater core.
Post by cn90 »
- Quick note: leave driver's side plastic kick panel out for a week to monitor if there is any leak.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
+1 Nice mod!
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Fantastic write-up! Thanks!
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Post by mecheng »
Well done! Your heater hoses don't look bad actually considering the age. No signs of bulging or cracking.
I'm suprised the o-ring causes the leak, you would think they would be able to size it properly as it is supplied with the Heater Core. Did the Volvo o-ring stop the leak?
Does the 5/8" heater hose fit snug on the 90deg elbow and the interior hose or is it loose but seals with the clamps?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Post by cn90 »
Hi mecheng,
- The reason for replacing is: look is deceiving at 18y/167K, it can burst any time, even without bulging first.
- O-rings that came with heater core: who knows where they came from, but they are not as thick as Volvo OEM. Every 1/10 mm counts when it comes to O-rings' sealing effect! Ordered Volvo O-rings, they will come later this week and I will follow-up on it.
- The 5/8-inch heater hoses slide into the cut pipes and the 90-degree barb fitting snugly. It is a nice fit, not very tight but slides nicely. Of course the clamps seal it well, zero leak at these junctions.
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
good tip on the OEM o rings. On a side note, I used the included ebay o -rings, and in the past 6 months, had no leaks ranging in temperatures from 115 to -25 *F. Only time will tell.
Question: How do you remove the crimp of the 90* degree coupler?
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
dosbricks
Been thanked: 4 times
Post by dosbricks »
Another question--has anyone else (to their knowledge) had the Estonian o-rings leak? I left my driver's side cover off a few days but could not detect any leaks checking with a paper towel.
Post by cn90 »
dosbricks wrote:Another question--has anyone else (to their knowledge) had the Estonian o-rings leak? ...
dosbricks,
The O-ring issue was discussed in the "infamous ebay heater core thread" below:
http://volvospeed.com/vs_forum/topic/15 ... ter-cores/
There appears to be no consensus, some have good luck with the supplied O-rings, some had to switch to Volvo OEM O-rings. One person has to "borrow" the yellow plastic spacer (used at firewall coupler) and place it behind the O-ring to apply extra pressure on the O-ring itself.
Post by cn90 »
UPDATE re leaking Ebay O-rings...
1. Every 2 days, this is what I get. I used the lid from take-out food to collect coolant lol...
2. I used a piece of plastic as "gutter" to drain coolant...
3. The Volvo O-ring seems to have the same thickness as the ebay O-ring.
I didn't measure the I.D. and compare.
4. My theory is the ebay heater core female section might be a tad too deep, so when you tighten the T25 bolt, the pipe flange barely squeezes the O-rings. So I went to local OReilly parts store and bought some M14 copper gaskets because the O.D. closely match the Volvo plastic ring (from the firewall coupler).
- In theory you can use the plastic ring from the firewall coupler but I didn't two (2) of these. Also after 18 years, the ring I have is somewhat brittle (the other one broke during removal last week).
- Copper is better.
- But the copper gasket O.D. is a tad too big and the I.D. is a tad too small.
- I used dremel tool and sand paper and make it close to the Volvo plastic ring.
- When all done the copper gasket must be able to seat INSIDE the heater core female section.
5. After the copper gasket is installed, zero leak. So my theory is:
a. Either the ebay O-ring I.D. is a bit too big (I doubt it), allowing coolant to leak past where the aluminum pipe meets the O-rings.
b. Or the female recess in the ebay heater core may be a tad too deep (something like 1/10 mm or so). This is enough to cause leak because the O-ring is not squeezed properly.
Whatever the cause, the copper gasket + Volvo O-ring fixed the leak!!!
