I know any suggestions will be us/canada based but if anyone uses ramps for oil changes can you post a link to the ones you use? just so I can see which ones would be suitable for these cars as I'm looking for some good quality rubber ramps and the best ones seem to be caravan levelling ramps due to the weight they can take.
The steel ones available over here get varying reviews due to them bending, which doesn't give confidence.
1998 s70 Car ramps
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Steel ramps should not bend or buckle if they are 'properly weight rated' to suit the vehicle supported and built to reputable required standards.
True that Volvo's are built a bit more solidly and weigh a little more generally.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
You can do a LOT more with a floor jack and stands.
A jack and stands offer a great deal more versatility.
Try to check your front motor mount with a ramp...
And you'll have a lot more room to work - Case in point:
difflock54
Your quite right but here (NZ) we get earthquakes reasonably regularly and the pic of the vehicle on just the 4 stands doesn't inspire a lot of confidence to be stuck underneath in a good shake.BEJinFbk wrote:You can do a LOT more with a floor jack and stands.
- Been thanked: 4071 times
I use plastic ramps (ABS) for all my oil changes. I haven't used my metals ones in ages. I use them even on the EV which weighs a lot more the either Volvo. They probably have some service life after which you sell them to a kid with a bike...
Nice! Wasn't doubting floorjack/axle stands offer more possibilities, just simply considering ramps as an alternative method solely for oil changes.BEJinFbk wrote:You can do a LOT more with a floor jack and stands.
These are the ones I nearly ordered (with extensions) as draper are a good brand but read the reviews and done some research on google and not that confident they would be suitable!difflock54 wrote:Steel ramps should not bend or buckle if they are 'properly weight rated' to suit the vehicle supported and built to reputable required standards.
http://www.amazon.co.uk/Draper-23302-Pa ... aper+ramps
- Been thanked: 504 times
Steel ramps are a pain to use.
Wood ramps are way better, info below...
DIY: 98 V70 Engine Oil Change (& ATF Change): the Easy Way!
https://www.matthewsvolvosite.com/forums ... hp?t=42989
- 10 Replies
- 1715 Views
Last post by 98v70dad
- 18 Replies
- 2308 Views
Last post by wizechatmgr
- 953 Views
Last post by BlackJack
- 1125 Views
Last post by Ben850
- 793 Views
Last post by louis_m_c
