1999 V70T5M reflections on servicing turbo CBV
This topic is in the MVS Volvo Repair Database » 1999 V70 T5 - Reflections On Servicing Turbo CBV
Has thanked: 1609 times
Been thanked: 4065 times
Yeah I did those. They are nasty putting the manifold back on. Separate thread.
Has thanked: 2198 times
Been thanked: 1851 times
Tried this on the 19T on my 2000 V70R. I couldn't get the top bolt out at all. Can only be done by removing the whole turbo. Standard CBV stayed in place!
With the bigger turbo you are totally screwed with the unit in car. I think I would try the water pipe removal before messing with nasty turn bolts though.
Getting to this thing is a big part of the problem. It's a back breaker working over top and back of the engine without a lift.
News of the day. With a refreshed CBV diaphragm and the IPD 16 psi spring, and new clamps on all the turbo hoses, I am hearing the wish..wish...wish of the turbo dumping much clearer when I lift. I don't remember hearing this on this car before
This is also confirmed with the sensation that I have another engine under the hood when the rpms climb above 2500..
Has thanked: 311 times
Been thanked: 817 times
So new diaphragm = improved performance. Yay!
I am curious, can you see damage to the old one if you hold it up to the light? I have seen a few where you could see breaches that way, but I am just curious because I have only seen a few.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Here's my brief write up regarding the replacement of the CBV on my '96. There's a pic of the failed unit as well
https://www.matthewsvolvosite.com/forums ... =1&t=64873
erikv11 wrote:So new diaphragm = improved performance. Yay!
I'll check and show some pix.
Russ..thanks for connecting to that earlier thread...good info
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I recently had to replace the inlet hose to the turbo coolant line on my '98 v70xc and did the outlet hose as well. While I was at it I bought a turbo inlet coolant hose for our '04 xc70 figuring I'll do that b4 it fails like our '98v70xc. Anyway, I was curious to know what were the symptoms to a failing CBV, performance differences, ect.. I was in that area doing the turbo coolant hose which was a real PITA, so I wanted to know what to look for in a failing CBV. Is the '98v70xc/'04xc70 similar enough to the v70t5 that I should investigate this area?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Link to a previous thread on this with some pictures
https://www.matthewsvolvosite.com/forums ... =1&t=38338
