Past several weeks it drops to min mark, and the "low coolant" warning lights up at the dash. This weekend was the third refill.
I have looked everywhere -- from heater core to hoses at the radiator. Today, I have a breakthrough, there is indeed white dried fluid residue over the engine mount cover surface, proximity to steering rack.
After running the engine to operating temperature, blower fan at 4 with heat knob at max. It confirmed my suspicion, not a trail, but enough drops to make the wetness visible. It stopped after dropping a cluster.
Minus Evaporator, ALL heating and cooling systems' parts were replaced in past four years -- a $1000 project -- blower fan and resistor November 2014.
The two hoses at the junction were the first items. I did not replace coupler at that time.
I will replace the coupler now.
I would replace the o'ring #7a, and gasket #8 on coolant pipe (item 7)
. Are there others that you would recommend? Like the two o'rings at the heater core itself. Heater core is Behr, replaced two years ago with new O'rings.
Thank you.
