2000 S80 idle fluttering
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 44 times
Been thanked: 14 times
Post by hu5ker555 »
2000 S80 2.9 non-turbo, 150k miles.
I was recently experiencing some fairly erratic idling. The tach would bounce around between 600 and 1000 rpm at idle. Sometime felt like it was about to stall. So I took apart the ETM and cleaned it up real well. Also sprayed clean the MAF. I tried to reset the ETM by disconnecting the negative battery wire while working. I also pulled the ETM fuse (#7), turned the ignition to position II, then turned it off, and re-inserted the fuse.
The erratic idling has been fixed. After warm-up, it now sits at a steady 650 rpm.
However, I can still hear the motor sputter a little bit every few seconds. The tach needle does not move, but the motor stumbles just a bit every few seconds. I've checked the vacuum lines and they all seem to be connected. Any suggestions?
Is it possible that the electronics just need some time to adjust to the clean ETM and MAF? I've driven it for about 5-10 minutes and have stopped/started the car several times now, but it's still happening.
jbkeene
Year and Model: 2000, S80, NA
Post by jbkeene »
could be the ETM
my symptoms were more severe than yours
I tried cleaning and PVC replacement, but it didn't help too much
ETM went bad and got a rebuilt unit from XeMODeX
smooth as butter now
hu5ker555
Post by hu5ker555 »
Thanks for your response.
I had some fairly severe symptoms, but now my ETM is clean as a whistle. No more RPM fluctuation. There is just a faint stutter every few seconds that I can hear, but no RPM movement.
Maybe I should check the PCV?
jbkeene
Post by jbkeene »
if you have never changed the PCV, surely it needs doing...gets wasted with oil
kits are available
syn oil helps keep it cleaner
would've been easy to inspect PCV when ETM was off...will need to remove ETM again to replace PCV
how about silly things...fuel filter, spark plugs, etc.?
hu5ker555
Post by hu5ker555 »
Thanks. Is there a way to easily check if my PCV is working properly?
hu5ker555
Post by hu5ker555 »
So I tested my PCV operation by giving it the rubber glove test. Seems to be working OK.
I do have a check engine light, so I pulled the code....P0302 cylinder 2 misfire.
I guess I need to check the spark plug and the coil to #2 next. The car runs great though (with the exception of a little stumble at idle). Hard to imagine that one of the cylinders isn't firing.
mumfy1973
Year and Model: V70 2000 2.4T, S80
Post by mumfy1973 »
Same as mine my Number 2 coil was playing up
jbkeene
Post by jbkeene »
yeah, look at the coils and wires...they can get crisp
tip: I remove the lower casing panel in summer...have actually had oil filter elements collapse due to heat
http://www.volvopartswebstore.com/showA ... 5.....part #8
hu5ker555
Post by hu5ker555 »
Got her fixed. I narrowed it down to coil #2 by pulling the code. This is the second coil I've replaced in two years. Also replaced all the spark plugs while in there.
Purrs like a kitten.
