Hi All,
I've been getting some water on the drivers side floor mat for a while. At first, I thought it was just straight water leaking in from outside, but after digging around, I'm fairly sure it's coming from the heater core area.
The real question is: Is the leak from the heater core itself, or from the connection between the hoses and the core? Pic is attached. Follow up question. Assuming it is the heater core, what's the recommended replacement part? Nissen or Behr?
Thanks for the help!
1996 850: Yet Another Heater Core Question
kimthepilot
- Year and Model: 1996 850 Wagon
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
hard to tell from the pictures. Your car being a 96 I would go with the heater core. I have used the $49.00 heater core from ebay Sweedish auto parts. Seems to work well. There are a number of posts regarding this core.
- Been thanked: 504 times
I did this a few months ago and wrote it up (using the "ebay" heater core):
https://www.matthewsvolvosite.com/forums ... hp?t=69238
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I agree with the above. I recently replaced the core on my '97 as a preventative measure. When I got the old one out I could see places along the plastic-metal bond area that showed signs of weeping coolant.
I wrote up a short description of some of the methods and tools I used during the replacement process here:
https://www.matthewsvolvosite.com/forums ... hp?t=67723
you better get on this as no heat in Canada sounds like a nightmare (already getting cold and its not even September). Even no heat in California is a problem. luckily, its doable yourself! Not fun but not bad, I did this job before I even knew how to remove my wheels and jack car up. READ THE DIY's here, where you cut the plubming and use heater hose instead.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- 16 Replies
- 2154 Views
Last post by erikv11
- 10 Replies
- 1904 Views
- 1117 Views
Last post by azureblue
- 1435 Views
Last post by Georgeandkira
- 19 Replies
- 3160 Views
Last post by Krons
