96' Volvo 850 Disconnected vacuum line
blankit
Year and Model: 850 1995
Post by blankit »
No idea where it goes to, it's at the fresh air hose.. the BCS vacuum line is plugged in but there's two inlets.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
On my '97 855, that line connects to the fuel pressure regulator. I wrote up a short guide to replacing the crumbling elbows with silicone tubing here:
Fuel pressure regulator vacuum line replacement
I made this repair a couple of years ago and it is holding up well so far.
Good luck and let me know if I can help out in any way.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
jreed wrote:On my '97 855, that line connects to the fuel pressure regulator. I wrote up a short guide to replacing the crumbling elbows with silicone tubing here:
No, fuel pressure regulator requires a vacuum source AT the intake manifold. Change it back asap!
That inlet at the piping is part of the TCV control
85 GLH, 367 whp
00 Insight, 72 mpg
Scholz
Year and Model: 1998 S70T-5
Post by Scholz »
It does infact go to the fpr. Your diagram even shows it, brother. Jreed saved me on that one. Spent an hour trying to figure it out the day I bought my first volvo.
