1998 V70xc. Oil/trans cooler line retainer
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
I added pic of said retainer I'm having issues with. The oil cooler line popped off the other day after swapping radiator and I'm looking for another retainer/clamp that would work on my V70xc.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
tryingbe
- Year and Model: None
- Been thanked: 26 times
People put clamp outside that clip so it would not come off.
https://www.fcpeuro.com/products/volvo- ... 842411k1-1
https://www.fcpeuro.com/products/volvo- ... er-6842411
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- Been thanked: 504 times
DIY: 1998 S70 GLT Trans Cooler Line Rebuild for $10!
https://www.matthewsvolvosite.com/forums ... hp?t=55794
NOTE:
1. The Clip has a THICK and THIN side: the THICK side goes toward the Radiator.
2. Screw-type clamp over the metal clip and it will never come off.
NOTE:
- Has thanked: 311 times
- Been thanked: 817 times
I use a zip tie to secure that clip. Cheap, super easy to use, bullet proof.
- shiloh51933
Thank you for all the replies.erikv11 wrote:I use a zip tie to secure that clip. Cheap, super easy to use, bullet proof.
I ended up doing the zip ties, 3 across as to cover entire retainer.
The radiator hose clamp over the factory retainer sounds like a good idea.
I found using a 5$ snap ring pliers from harbor freight made it a trivial exercise. Allowed me to remove the years old clamps without deforming them. Could have reused them if I hadn't purchased new.
I used needle nose pliers the first time and couldn't get it off without ruining the clamp.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I use the cheap-o HF snap ring pliers too. They work well for opening up the clamp just enough to allow the lines to be pulled out. The picture below shows the old way that I used to do it before I realized that you only need to pry the clamp far enough to allow the lip on the clamp to clear the fitting on the radiator.
- shiloh51933
I got snap ring pliers but I the bottom right retainer was deformed, I bent back into place best I could after paying $13 bucks for aftermarket retainer's that were made of tin foil!! Thanks guys for your contributions.jreed wrote:I use the cheap-o HF snap ring pliers too. They work well for opening up the clamp just enough to allow the lines to be pulled out. The picture below shows the old way that I used to do it before I realized that you only need to pry the clamp far enough to allow the lip on the clamp to clear the fitting on the radiator.
- 2092 Views
- 2088 Views
Last post by fitz548
- 1458 Views
Last post by james321
- 1721 Views
Last post by justanotherhumanoid
- 1490 Views
Last post by tryingbe
