2000 s40 vacuum question
1996 - 2004 S40
1996 - 2004 V40
Hennimessi
Year and Model: S40 2000
Post by Hennimessi »
im looking at the vacuum line diagram under the engine and can't under stand where the vacuum lines are. what is a good line to use if i wanted to run seafoam through it and where is it located?
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
Any vacuum like will likely work. They're all connected to the intake manifold somehow.
My guess would be to use whichever is easily accessible and closest to the throttle body.
'84 Prelude
'06 MPV
'13 Ford Focus SE
Hennimessi
How do I know what lines are vacuum lines? Could you give me a certain point that runs to the intake manifold? Thanks for the reply
alschnertz
Remove the plastic cover from over the throttle body and you will see a vacuum tree.
Any of those ports are attached to the intake manifold.
Beware though. It is not unusual for the plastic vacuum tree to break from age when fiddling with the hoses that are connected to it.
'84 Prelude
'06 MPV
'13 Ford Focus SE
