1998 V70 XC Cross country. Trans let go. possibly ECU
Ben850
Been thanked: 7 times
Post by Ben850 »
I had posted in the Maintenance log.
The engine is running beautifully with the '98 T5 ECU I had installed.
What had happened today has confused me.
After ten miles or so, the transmission became abstract.
To understand what I had done is simple really, I had taken the ECU from a T-5 of the same year which had made the car run well.
The transmission sad no.
If I had utilized the TCM from the same donor would that have been the way to go?
I will dump a new trans in if I have to.
I like the car.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Was the ecu from a car with auto transmission or manual?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Ben850
Post by Ben850 »
It was auto.
I am going to get the car home and try a drain and fill.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
The pit road rule back in my NASCAR days was to undo that thing you just did, presuming you still have the original unit. Odd that it ran for a while before becoming unhappy. If it looks like a random unrelated, my 850 turbo scared me once with tranny-failure symptoms but it turned out to be what is sometimes called the neutral safety switch; once replaced it worked perfect for another 50k until a guy tried to put his front bumper through my ribcage.
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
Nothing to add but I like the concept of an abstract transmission
Has thanked: 1609 times
Been thanked: 4064 times
skloon wrote:Nothing to add but I like the concept of an abstract transmission
I think that sounds shifty
Ben850
Post by Ben850 »
I have to add another possibility.
I hag just replaced the radiator and hadn't yet topped off the fluid level.
I did add fluid after the symptoms started. I'm afraid it was too late.
I hope I didn't smoke the trans from too little fluid.
I may have burnt the fluid though.
How much does the Trans cooler in the radiator typically hold?
I will try the drain and fill and cross my fingers.
Has thanked: 2197 times
Been thanked: 1851 times
Been there and done that. The first time I did a fluid flush on my 850 auto, I forgot to re-check the level before taking it for a run. Like you I nearly had a personal malfunction in the back of my pants when the trans ran rough. Once I got home I found the fluid level was well below minimum. I'm not sure on the quantity in the radiator cooler, but with the pipes to/from I'd say at least a pint.
Hope all it turns out to be is a low level of fluid. Top it up and run a short distance and see how it goes and smell the fluid for burning. If it is burnt, do the trans drain and flush and fill 2-3 times and see what happens.
Wish you luck!
