1998 S70 Oil light On-no leak and its fulll
bmball73
Year and Model: 1998 S70 and C70
Post by bmball73 »
I have a 98 Volvo s70 and my oil light came on after driving about 15mins. There is not a leak and the oil is filled. Also, the heater is not working....I didn't know if these two were related. Any thoughts?
Has thanked: 292 times
Been thanked: 765 times
Well this wouldn't explain them being related (can't see an obvious connection between them actually), but for the oil light check the oil pressure sender connector, it may have come unplugged. It is under the intake manifold, you can see it pretty easily with a flashlight.
For the heater do you mean the fan will not blow air? Does it work on the highest setting, or not work no matter what?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1506 times
Been thanked: 3819 times
Check the fuse listings to see if there's a common fuse.
Don't run engine until you confirm oil pressure
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Check the fuse first for the heater. I don't think these issues are related. Any signs of leaking heater core?
Been thanked: 472 times
Post by cn90 »
Stop driving the car until the diagnosis is made.
Possible culprits for low-oil pressure:
- Low oil level (you said you already checked it).
- Clogged screen on oil pump
- Clogged oil filter
- Engine sludge
As mentioned by others, hook up a pressure gauge and take readings, then report back.
Despite everyone else ignoring it, the first thing to do is to check the wire and connector I posted about! :D
It is easy for the little white plastic plug to come unhooked from the pressure sender, and when it does the light turns on.
'06 S60 R, 197k
Erik is correct on the wire being the first thing to inspect.
bmdubya1198
Yeah, do the easiest first. Saves lots of time if it is the culprit!
Post by cn90 »
Learned something new...
In the BMWs, the oil pressure sensor works differently:
- Engine OFF: circuit is CLOSED (zero Ohms).
- Engine running with good oil pressure > 7 psi: circuit is OPEN.
I guess Volvo design is different.
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
The obvious concern, of course, is that oil pressure might have fallen. So I agree with the above suggestions, first look for the easy solution. Maybe even try changing out the sensor. If the oil light is still on, is the problem in the circuitry or actual low oil pressure?
O'Reilly's Auto Parts sells the gauge you'll need to find out. Carquest has the fittings to hook it up if O'Reilly's doesn't. You might not need to start it, just spinning it over for 30 seconds with spark plugs out and 12v. wire to coil disconnected should produce enough pressure for a reading on the gauge.
Good luck.
