Replace senors or is there something else I should look into first?
ABS-312 Right Front wheel sensor signal, fault in circuit
ABS-313 Left Rear wheel sensor signal, fault in circuit
ABS-314 Right Rear wheel sensor signal, fault in circuit
1998 C70 Coupe, ABS DTC Topic is solved
- RickHaleParker
- Been thanked: 981 times
Active
Past
Past
The ABS module itself is usually the culprit. Common failure point. I've personally seen it on two vehicles but it always manifested as right rear wheel sensor and pump DTCs for me. Weak factory soldering is the issue. Can DIY repair or do what I've done and gotten a rebuilt module.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
With a faulty module you are generally going to have a faulty reading or extrapolation code in addition to each circuit fault code. You typically won't have a bunch of opens like that by themselves UNLESS the codes were cleared from the module before. Test the circuits through the harness to confirm if the are open circuits or not.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- RickHaleParker
It looks like my first attempt to repair should be to pull the ABS module, grab my heat gun and do a solder reflow.
Now to find the time to Git-R-Done.
Active
Past
Past
goldmandan
- Year and Model: 1999 S 70, 2000 V70
I have a good working ABS module lying around off a '99 C70 if you need one. Hit me up [email protected] I'll let you have it for $50 shipped
Dan
Dan
- RickHaleParker
'99 - '00 module is not the same as '96 - '98 ... They changed the OBD communication in '99
Active
Past
Past
- Has thanked: 1614 times
- Been thanked: 4078 times
You can check sensors by looking for about 1000 ohms resistance on the plug without removing them
The success of people re soldering them and getting more than 6 months seems to be about 20%.
Mattymoo at Midwest ABS here sells tested recon units.
- RickHaleParker
I replaced the ABS module with a remanufactured unit, problem solved.
Active
Past
Past
- 13 Replies
- 3417 Views
Last post by RickHaleParker
- 9 Replies
- 6641 Views
- 932 Views
- 1970 Views
- 653 Views
Last post by dosbricks
