I've got 1991 Volvo 940 with B200E engine.
My problem is, that in last two months, my pump relay was burned twice. So now I monitor it's temperature while driving, and realized, that front lights relay also gets hot. And I mean hot. After driving for a while it's hard to keep finger on any of these two relays.
My local mechanic said, that the relay tray was burned and he replaced it. But not the individual sockets, just the main board. Now I'm really worried, that pump fuel relay will burn again and car will stop in the middle of way. I do have a spare one if this happens, but what if it will burn also?
My mechanic also said, that he measured the pump current and it seems to be fine.
And about the lights relay: I replaced it with new one, and it also gets hot, even when I will pull out the lights fuses - so I guess there is a problem with control circuit - not the load.
Do you have any ideas what cause the problem? I would also appreciate any advices or manuals how to measure and check what is wrong.
I attached photo of my relay socket. The pump relay is the green one, and the front lights relay is the metal one with letter K
(2nd from the left).
Thank you!
