2000 V70 XC is a poly upper mount really a good idea?
Has thanked: 2207 times
Been thanked: 1852 times
Careful with those mounts. There is another at the LH rear corner of the trans on an AWD, and the upper mount may not be the correct one for a 2000 V70 XC. That is not the mount on my 2000 V70R. The crankshaft mount is also not the one shown.
http://www.ipdusa.com/products/7392/112 ... 70-v70-awd
Crankshaft mount
http://www.ipdusa.com/products/7257/112 ... 70-v70-awd
LH rear mount at trans
http://www.ipdusa.com/products/8078/115 ... izer-mount
Top torque mount
Finally the lower torque mount is not correct for a P80 AWD according to the FCP listing.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
So I'm back to replacing the upper torque rod bushing on my '98 V70. I last did the bushing a few years back, probably close in time to my engine replacement -- which would have been 3 years and 60,000 miles ago. Has anybody had one of the original rubber style mounts last more than 60K miles? It feels like every time I look under the hood that bushing is on its way out. I know that isn't the case, but they sure do seem to wear out quickly. Any thoughts on that?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Been thanked: 504 times
Post by cn90 »
The factory Upper Mount Lemforder is about 60K. Basically it cracks from the fore and aft motion of the engine torquing back and forth.
A ghetto fix is to fill the voids (the fore and aft voids) with silicone caulk.
E Showell
Post by E Showell »
I'll keep the improvised improvement in mind. Thanks.
'95 855 auto (sold)
Has thanked: 311 times
Been thanked: 818 times
They wear out quickly. I think at 60k you were very fortunate, on my cars the OEM mount lasts more like 40k. Maybe because I don't drive so many miles per year.
E Showell
Post by E Showell »
Erik -- Either I'm very lucky, or not very observant. Could be it wore out long ago and I just never noticed!
'95 855 auto (sold)
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
dosbricks
Been thanked: 4 times
Post by dosbricks »
Those Lemforders are sure hard to squeeze in there. I have a couple of thick oak blocks--one of which is milled on one side to draw it through just enough to center it--using a long 1/2" bolt. I'm wondering if it would be worth it to put the mount in the freezer overnight and if it would stay cold long enough to make installing it a bit easier. Anybody try this?
Yes Dos, that freezer trick has been recommended before, many people swear by it ... great minds think alike!
https://www.matthewsvolvosite.com/forums ... hp?t=43089
etc.
Post by cn90 »
The freezer trick helps, but even with oil and by the time I have the bearing adapter in place to go, the Lemforder bushing is probably at room temp anyway.
It is still a big pain to press it in, and I only got it 80% of the way in the the bearing adapter just stops!
Next time, I will sand the bushing O.D. a tiny bit so it slides in easier. They over-design the thing too tight, no need to!
I have a belt sander so I can remove a bit of stuff on the Outer Diameter.
