Replacing 850 Upper Torque Rod Bushing
dustinclish
- Year and Model: 850 Turbo 1994
I received my bushing from FCP today and put it in the freezer. I would love some tips on replacing it myself or even link me to an older post that I haven't found yet. Your help is appreciated greatly.
- Has thanked: 311 times
- Been thanked: 817 times
Great stuff in the repair database here at MVS
Replace upper engine mount w oem bushing
https://www.matthewsvolvosite.com/volvo- ... abase-home
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Freezer and cold, soapy water!
I took a vise grip and turned it upside down to help press it in - clunky and heavy, but it got the job done!
'98 S70 T5
2016 Chevy Cruze Premier
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
From IPD
PI-394 HD FIREWALL MOUNT INSTALL GUIDE.pdf- (1.02 MiB) Downloaded 340 times
98 S70 T5-M Brick for life
That is a great guide from IPD but OP is replacing the torque mount, not the firewall mount. And using an OEM style, not poly.
Juan62
here you go...
PI-213-ENGINE-STABILIZER-MOUNT-INSTALLATION.pdf- (1.82 MiB) Downloaded 311 times
PI-363 LOWER TRANSMISSION TORQUE MOUNT INSTALLATION INSTRUCTIONS.pdf- (4.93 MiB) Downloaded 233 times
Juan62 very kind of you, but none of these IPD installation guides are useful for what he is doing, I was trying to say that in my last post. OP is installing OEM style, not poly. I just went and looked at their site, IPD does not appear to have an installation guide for this part.
dustinclish
I got it in about a third of the way using a pressing device made out of a bolt, pipe flanges, and a series of different sized washers as demonstrated in Geev's tutorial. I busted 2 bolts in half though (the second being the biggest bolt i could fit through the bushing) After that I just took a hammer and hammered away at it in a circular pattern for about 15 minutes and it did the trick : )
- 1772 Views
Last post by dairyqueen814
- 13 Replies
- 3639 Views
Last post by theWIFES_S70
- 867 Views
Last post by lext
- 707 Views
Last post by 454cid
- 678 Views
Last post by MoVolvos
