Jellobmw wrote:+1 on toptiergas and double +1 on ethanol free!
MA, CT and RI only offer gasoline with 10% ethanol. It's the law or something...
We've got the good stuff up here in Albany...come visit and bring a bucketRussB wrote:Jellobmw wrote:+1 on toptiergas and double +1 on ethanol free!
lol. my first thought reading that was "There is gas without ethanol?" Thanks for clearing that up as CT/MA/RI is >90% of my driving.RussB wrote:Jellobmw wrote:+1 on toptiergas and double +1 on ethanol free!
I am surprised. I have found that the availability of real gasoline is proportional to your geographic distance from Iowa. In Missouri and Kansas about the only place that I can buy unadulterated gasoline is at a marina or an airport. I was in Louisville, Kentucky on a small job a couple of years ago and filled up the Platinum with 98 octane real gasoline. I couldn't believe how well the car ran and how good the gas mileage was. I didn't even think of stopping to fill up until I was West of St. Louis which was about 65 or 70 miles further than a normal (e10) tank of gas will take me. Premium around home with the ethanol blend is 91 or 93 depending on the gas station.RussB wrote:Jellobmw wrote:+1 on toptiergas and double +1 on ethanol free!
Put new plugs/wires on it in the fall, should have done the distributor cap/rotor while I was at it...BEJinFbk wrote:I'd consider having a look for something on the ignition
side if this happens again. Probably moisture related.
98?! Wow! I'm taking a bucket to Kentucky ASAP. I've honestly never seen anything higher than 94 at a pump. 93 is the highest octane they sell here in MI.Ozark Lee wrote:I am surprised. I have found that the availability of real gasoline is proportional to your geographic distance from Iowa. In Missouri and Kansas about the only place that I can buy unadulterated gasoline is at a marina or an airport. I was in Louisville, Kentucky on a small job a couple of years ago and filled up the Platinum with 98 octane real gasoline. I couldn't believe how well the car ran and how good the gas mileage was. I didn't even think of stopping to fill up until I was West of St. Louis which was about 65 or 70 miles further than a normal (e10) tank of gas will take me. Premium around home with the ethanol blend is 91 or 93 depending on the gas station.
You can probably get avgas at Landmark Aviation at GRR if you make some friends over there. Bring deep pockets though.benpineapple wrote:Put new plugs/wires on it in the fall, should have done the distributor cap/rotor while I was at it...BEJinFbk wrote:I'd consider having a look for something on the ignition
I have the same problem here, we only have 91 Octane max. We used to have 94 but Sunocco a couple years ago pulled out of the country.Ozark Lee wrote:I am surprised. I have found that the availability of real gasoline is proportional to your geographic distance from Iowa. In Missouri and Kansas about the only place that I can buy unadulterated gasoline is at a marina or an airport. I was in Louisville, Kentucky on a small job a couple of years ago and filled up the Platinum with 98 octane real gasoline. I couldn't believe how well the car ran and how good the gas mileage was. I didn't even think of stopping to fill up until I was West of St. Louis which was about 65 or 70 miles further than a normal (e10) tank of gas will take me. Premium around home with the ethanol blend is 91 or 93 depending on the gas station.RussB wrote:Jellobmw wrote:+1 on toptiergas and double +1 on ethanol free!
