Fixing fuel door lock/how to/UPDATE
Has thanked: 292 times
Been thanked: 765 times
Re: Fixing fuel door lock/how to/UPDATE
From Robert:
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Been thanked: 472 times
Post by cn90 »
As I mentioned above, some people remove the plastic tab on the fuel door.
Small risk of vandalism (I doubt it) and you don't have to deal with this issue of door actuator again.
To remove the plastic tab, it is very easy:
1. Lift the metal tabs up a bit (#1 in RED).
2. Slide the plastic tab out (#2 in YELLOW).
I have not done this yet, but I might.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
erikv11 wrote:From Robert:
Nice video! Perfectly explained (Robert's ego is growing now as we speak :)
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
mecheng
Post by mecheng »
cn90 wrote:As I mentioned above, some people remove the plastic tab on the fuel door.
Good pic, I agree though. I am also worried about punk kids; you know....the new generation. :mrgreen: I've heard sugar in gas can do some real damage.
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
Thank you very much for this write up, Misha! I just did this fix. I had been experiencing intermittent issues for a while but the fuel door would open on the second try most of the times. Today however, I was unable to fill up at all so finally got myself to using your how-to and tackling this issue. I had to do it 'McGyver style' by the side of the road but was able to clean the rotor (used brake cleaner that was in my trunk) and oiled up the mechanism with clean motor oil (did not have anything else in my car...). Would have liked to done it on the workbench but had to do it ro be able to fill up, didnt wanna drive with the trim opened up. Took me 45 min and so far works great!
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Do you know that there is emergency handle in the trunk in case that fuel door would not open?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jvl
Post by jvl »
Well, there is a lever/handle on mine, but that is on the solenoid itself (so hidden deeply behind the trim), once at that point it was easier to just undo the 3 screws and clean the motor right away. I did look for the emergency handle that you (and others in other threads) mention, but did not find it. Maybe it's different in European models?
misha
Post by misha »
It's not market dependable,all of them have it unless some previous owner(s) ripped it out.It's behind the trim and look like a piece of wire with a circled handle,but easy to find when you know where it is.
As you can see mine is EU model.
However...i'm glad that my post was helpfull.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jvl
Post by jvl »
Hmmm well mine does not seem to have it:) on mine, there is a black plastic tab at the side of the solenoid you can pull. This tab is invisible when the solenoid is mounted, so I only found out the tab was there at the point I almost had the thing pulled out. Good to know for others, maybe. No sign of a cable or wire previously being installed as far as I could tell! Thanks for the tips on disassembly, the description was so clear that I was amazed that I did not need a visual to imagine how to do it, with the parts in hand the description is very accurate and clear!
misha
Post by misha »
Thanks! ;)
The repair was done 7 years ago and my fuel door lock still works like brand new.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
