Hello all,
When my driver door is closed: the driver window, lock and turn signal does not work (and makes a little noise in the door) and when I use the left hand turn signal the "door open" sensor is activated and I get all warnings and interior lights turn on. What's weird is that the buttons on the driver door for the other 3 windows DO work and when the door is completely open, everything works fine. I just don't understand!!! Any ideas before I take it to the dealer and empty my wallet?
2007 XC90 V8 Sport - Weird driver door electrical issues
speedyswede83
- Year and Model: 2007 XC90 V8 Sport
sounds like something in the door loom is shorting out and causing the rear control module to freak out, if you're not into electrical diagnosis - be prepared - all labor to track down the problem - then chances are there's a hardware item at its end that will explain (and needs to be replaced) it.
Good Luck.
Good Luck.
mzsunshine99
- Year and Model: Volvo xc90
Any updates on this problem? I am having the exact same issues. Any Help is appreciated.
- 1033 Views
Last post by precopster
- 604 Views
Last post by speedyswede83
