1999 V70 T5 - Broken Hatch wires lead to no-crank condition, Manual trans 9168056
This topic is in the MVS Volvo Repair Database » How To Troubleshoot Volvos
Has thanked: 1609 times
Been thanked: 4065 times
Trying to get home, pulled over and no start.
No cranking.
I also noticed by FOB has stopped working, will not unlock any doors
Also, driver door lock switch no longer locks doors
All idiot lights come on but I get the click of a dash relay but no cranking.
Checking fuses......
Fuses all look good. Trying to find some wire to jump the green red starter bypass
On edit - I probably missed this in the dark
Fuse 6, central locking was blown and may have been root cause.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
I know this does'nt help you now, but low battery due to alternator failure? Stay safe and warm, feeling your pain.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Negative cable broken or loose from corrosion? Bad battery/alternator combo? Or simply loose terminal connections?
Also -> Amazon link
dosbricks
Been thanked: 4 times
Post by dosbricks »
Agree with kahl and Matt. The door lock issues make it sound like you are out of juice. Headlights dim?--working?
Battery fine.
I rigged the starter bypass, being stuck in the a Walmart parking lot (where I was getting a trailer bulb, having talked my way out of a ticket) bought some primary wire, and VROOOM>>> she started right up.
On the way home, the clutch pedal would not drop off the cruise control, so Im guessing a bad clutch switch. On ME7 - this switch has multiple functions.
Of course, with my locks not working, its either coincidental, or I have a fault higher up that is common to the clutch switch and locks. Im guessing this is the case.
Home, safe and sound. 2 hour delay total.
Looking at circuit diagram, nothing in common. I'll put new batteries in the fob
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
Good for you and impressive that you got it going again. I would have been stumped beyond checking the batteries (car and fob).
I had looked all over the engine compartment for the red green starter bypass wire and concluded my car didn't have one. While checking fuses, I noticed it in a large white connector under the cover.
I was heart sunk as my brain was telling me I had an immobiliser problem with both the FOB and door lock not working, so I was surprised when the bypass worked.
Be careful remote starting with a MANUAL Transmission!!
I need both a roll of wire, fused and a cutter in my " always in car" toolbox in the spare compartment
Well, the plot thickens this morning.
No cranking with the key, car cranks fine with the bypass, but will not start!
This car always starts in 1/3 of a second, so something else is up.
