Nivomat isn't exclusive to the V70Rs. I've seen a '98 V70R without the Nivomats. My V70 AWD (non-R) has Nivomat. There are a couple threads around for which non-Nivomat shocks/springs to get if you're doing a conversion. Also bear in mind, lower control-arm is different for Nivomat equipped models (at least on my 98), it all mounts differently up top as well as below.Jazzop wrote:If it has Nivomat, I would switch to standard suspension as soon as it started acting up or if I were already doing work back there (e.g., replacing brakes or bushings). Is the Nivomat an option, or was it standard on the V70R? I've never dealt with it before.
Make sure the thing has a rear driveshaft. Runs on the PS next to the exhaust. Should be pretty obvious if it's missing.
