Hello everybody,
Last time I took my car for ordinary maintenance, it was found out that the oil dipstick currently installed in my engine is not the good one. Therefore the indication for oil level is wrong. Obviously this can be dangerous for the engine, because I might not realize when oil topping is needed.
I was told that the good dipstick is s/n 9497470
Now, for some reasons, it seems impossible to find all around the world this part.
Therefore I started looking for 2 options, for which I need the help of any of you owning a V70 with a 2.5 D engine (2461cc, 140 HP, I believe is the 5252T but without turbo) :
1) may I ask you to check on your dipstick what is the s/n reported there (it's between the min/max indications)?
I found out there are some s/n which comes from Audi / VW because this engine was originally designed by them. If this is the case, I might be able to find a good dipstick under another s/n
2) In case you have the dipstick 9497470, could you please take the a couple of measurements:1) from the gasket to the "max" indication, 2) from the gasket to the "min" indication. Please, be as precise as possible!!
Thank you so much to any of you who will be able and so kind to help me!!
Looking forward for your anwers
Matteo
V70 2.5 D oil dipstick wanted
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You're on the wrong forum.
There are no Volvos diesels in u.s.They hadn't been imported.
I suggest www.volvoforums.org.uk
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1611 times
- Been thanked: 4075 times
One of our Volvo-D forum members in the EU should be able to help but honestly your Volvo Dealer in France should do this too.
- 22 Replies
- 4648 Views
Last post by newbieofthenorth2+
- 1238 Views
Last post by bmdubya1198
- 976 Views
- 435 Views
Last post by CIK7
- 14 Replies
- 960 Views
