Howdy all. So I've heard this addressed in passing, but haven't necessarily seen a general consensus on the issue of a timing belt that visually checks out. I purchased my 98 V70 at 175K, it's now at 204k. I have no indication of when the timing belt was replaced; there aren't any stickers under the hood, or in the manual to let me know. Visually, all components look fine. Hydraulic tensioner is dry, no leaks. Water pump is dry, no leaks. I manually turned it over, and all 3 timing marks line up perfectly. Belt visually looks fine; teeth don't appear to be worn down, no cracking visible. The belt has the Volvo logo, and Volvo OEM part # on it, so I'm assuming the timing belt was changed at a dealership.
I have purchased the complete kit (belt, tensioners, water pump), and will be replacing all components in the coming weeks, as I have no definitive proof of when it was last done. Going on some extended road trips this coming summer, and don't want to have to worry about it.
My question is this: if the timing belt and all other components look okay, are they okay? Any instances you've seen or experienced where things looked fine under the timing cover, and something went wrong?
Timing Belt Looks Okay
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
- Has thanked: 2215 times
- Been thanked: 1853 times
I'm not trying to speak for everyone here, but the normal response is if you don't know when it was done last, no matter how it looks do it!
The cost of doing this verses a broken component/belt/tensioner/bearing/whatever that wrecks you engine, it is a relatively small price for piece of mind. This will possibly see the car out now.
- kippster41493
- Year and Model: 1994 850
Haven't had the joy of it on my own vehicle, helped a friend replace a water pump because it showed now signs of leaking and was heating fine for a while. 2 or so months later he started over heating with no signs of loosing coolant, took out the pump and the fins had worn off pretty good. I have no idea how common that is (was the first time I've seen it) but other than that I wouldn't worry too much if everything looks good. Not very often does something that looks good really isn't. Doing the belt and components is most likely good enough, not a whole needs to be changed. When I did the belt on my 98 V70 I honestly only replaced the belt because everything else looked fine, pulley spun freely, no leaks. So in my experience, what you're doing is more than fine.
1994 850 2.3 Turbo
1998 V70 GLT 2.5 Turbo
- project now
1995 BMW 530i
1998 Eclipse GSR - 3.5" off the ground and headers
1995 BMW 530i
- Has thanked: 1613 times
- Been thanked: 4077 times
Based on stats gathered here I would venture , which is a guess, the MTBF on belts is well over 150% of the service interval
For the pre 1999, that means well over 105k miles.
The user claims all liability for use of my conjecture.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Only for the belt, inspecting it implies turning little by little the engine and have a close look at the belt to cover it's entire length. If it doesn't show any crack at any point, to me that is good.
If you replace the water pump, make sure to use either a Volvo part or if available and Aisin replacement part. I have read too many posts about aftermarket pumps that didn't last 30k miles.
- Has thanked: 312 times
- Been thanked: 818 times
The way the timing belt looks is of almost no relevance, unless it looks really bad. That is because the timing belt itself basically never fails, it is failures of the water pump, pulleys or the tensioner that have ruined P80 engines.
The biggest red flags are a pulley that wobbles, or one that spins freely. In the latter case the bearings are dried up and it should be replaced at once.
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
I bought my '00 S70 with 195k miles. I replaced the T-belt, tensioner, idler and water pump right away. I had no info regarding the last change, and I don't like to take chances.
benpineapple
Was planning on blaming you.abscate wrote:The user claims all liability for use of my conjecture.
Thanks all for the input. Doing the change this weekend with all Volvo components. Too risky to leave it up to chance.
We have really good lawyers here on MVS.
I went way over on mine but I won't do that again on any car and Ive been depositing heavily into the karmic bucket since to make up for that withdrawal. Just did the P2 at 100k/10 years proactively.
- 13 Replies
- 6256 Views
Last post by wyoben
- 612 Views
Last post by erikv11
- 20 Replies
- 8496 Views
Last post by jvl
- 5522 Views
Last post by WhatAmIDoing
- 5331 Views
Last post by Eddystone
