Could Weak Ground at Block Prevent Warning Light Op?
warmblood58
Year and Model: 1989 245
Has thanked: 5 times
Post by warmblood58 »
Still struggling to get power at Fuel Pump (pump jumps fine) and Warning lights are not coming on in Position 2 (dash lights come on ) This car sat for 6 months. Strangely, yesterday, I forgot to attach ground at battery but blue wire was attached and I did get a few warning lights, so could this mean ground at engine block is at fault? How best to access these connections? I did replace fuses and bridged fuel pump relay. Thanks, gotta get this car (95 850 T5-r) running!
Been thanked: 4065 times
Bad grounds will cause all sorts of weird thing to happen. You must have had something attached to the negative side or else causality will be violated.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
A DVM (DIgital Volt/Ohm Meter) is your friend in these cases. Although they are total junk, the $5.00 Harbor Freight special is better than guessing. For about $25.00 you can get a meter that is actually decent at places like Lowes or Home Depot.
warmblood58
I checked voltage at pump connection, nothing with key in pos 2 and relay removed with 15/87 pins bridged. The lack of warning lights have me stumped - I will check continuity when and where I can. Best way to access negative cable connection? Does it terminate near oil pressure sender. My car is pointed down hill unfortunately (vs a nice level driveway) and as it is a T5-r, access under the car is limited though I suppose I could jack it up in the front and carefully block and jack - don't usually work on cars that are not on level services.
The block attachment point is indeed near the sender if it is like my V70
Park and use the curb to scoot under.
warmblood58
thanks, car not running so . . .
