Hi all--
Recently changed the evap J-Hose on a 2001 Volvo XC70 AWD. I've changed evap hoses on all forms of S/V70's and 850's but this was a new form of hell. The charcoal canister is above the rear suspension and fuel tank and is completely inaccessible from below. In fact, most shops--including the dealer--state that the rear suspension has to be removed and the job bills out at well over a grand.
Undeterred, I set about accessing the hose from the top by cutting through the rear of the wagon with a Dremel tool. I was able--after many setbacks and much frustration--to access the hose and replace it. I riveted sheet metal over my cut, painted it with bed-liner coating and RTV'd the seams. All told the job took around five hours and saved countless dollars. For what it's worth, I did post in the 2001 XC70 forum asking for advice regarding this job but no takers--perhaps because many folks would rather live with the DTC than undertake this beast of a job.
First, for what it's worth, the 2001 J-Hose is longer than the standard hose. It's Volvo part number 9155990 and the hose is several inches longer than the mid/late 90's hose. Here's the 2001 hose.
Next, I cut a hole to access the bottom part of the hose--using a standard Dremel Tool and cutting wheels.
Next came the tricky part. Accessing the top of the charcoal canister (where the J Part of the hose lives) requires cutting through the top layer and then another about five inches deeper. This was the most difficult part of the job as the seat-back bracket landed square in the middle of the section that needed to be cut out. It was necessary to remove the rear seats (disconnecting the rear airbags as well). The top cut had to be much larger than the needed second cut in order to actually get the Dremel tool in a position to effectively make the required cut. This was a real PITA.
Once the hole was made it was fairly easy to remove the rotten hose and install the new one--about ten minutes work. The old hose was riddled with cracks.
Next, I took an old piece of sheet metal (actually an old Duralast Battery sign) and cut it to fit. I riveted it in place with 3/16 Aluminum rivets.
Finally, I coated the metal with truck bed lining and soundproofing, and spread RTV around the seams to finish the job. It turned out really well.
Once dry I reattached the rear seats (another PITA) and tightened everything back down. Bingo. Job complete.
Final thoughts? This is a real PITA and it's incomprehensible how much more difficult the 2001 XC70 canister is to access than all prior year models. I still maintain that accessing it from the top is easier than from the bottom and can't even imagine dropping the rear suspension to complete a 10 minute hose swap. All told I spent about $25 bucks on parts (sheet metal, rivets, RTV, and hose) and it took about three or four hours--most of which was spent using Dremel tool to cut access points and cutting sheet metal to repair.
I also made the maddening mistake of disconnecting the rear seat airbag before disconnecting the battery, thus triggering the SRS light that--from what I understand--must be taken to Volvo to reset. It's surprising to me that astonishing lack of information on swapping this hose as it's so much different and more difficult than all prior years. I hope this write-up helps folks in a similar position.
Eric
Athens, GA
2001 XC70 AWD J-Hose Replacement FIX with photos
2001 XC70 J-Hose Replacement Fix w Photos
If you can wait I can bring my Autel down and reset that light for you..ill check schedule
deepsouth
- Year and Model: 2001 Volvo XC70
- Been thanked: 11 times
Thanks for the offer--that would be terrific! I had the battery unhooked but hooked it back up to move the car a few feet backwards. Forgot about it and the next day removed the seat. Ugh!
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
2001 XC70, 129,000
- Year and Model: Lots
- Been thanked: 128 times
Found out the hard way last week that Aussie P2s aren't shipped with an evap system. This was a total surprise as we usually follow the emission standards of the USA pretty closely. We upgraded a 2001 S60's ECM with updated USA firmware to alleviate ETM codes. Upon scan we had a fuel tank pressure sensor and canister shut off valve fault because the hardware simply wasn't there.
Another thing to consider here is, on a 15 year old car which probably needs new suspension parts, drop the rear frame and tank and renew all the evap parts during that job.
Add inspection and reseal of those plates to your annual check over list too.
Nice DIY!
Nice DIY!
deepsouth
Thanks! I thought about dropping the suspension but just couldn't bring myself to do it with laundry list of other things that need attention. I intentionally made the inspection hole large enough that I can easily access all of the hoses below. Hopefully, I won't need to!
2001 XC70, 129,000
2001 XC70, 129,000
jenkinskg
- Year and Model: 04 c70 hpt 98 s70 xc
Good article, I have same issue on 04 s60 metal tank, single sided fuel pump.
I am told the hose is similar to your description.
There are 2 hatches, not sure if that helps at all, changed fuel pump 6 months ago and did not see any access to j hose.
Was told the tank would need to come down
2004 c70 2.3HPT, s60 2.5T
deepsouth
I believe it's in the same spot. What I don't know is where you'd make the cuts in order to access it. I started by using an inspection camera to pinpoint the exact location and then drilling pilot holes with a foot long 3/8 drill bit (from the bottom). That helped me determine exactly where to cut.
Good Luck.
Good Luck.
2001 XC70, 129,000
2001 XC70, 129,000
I had the pleasure of changing my J-hose today on my 2001 XC70...After I read the post about cutting a hole above the rear axle, I kind of freaked out. But after weighing all options it was the only way to do it without dropping the rear-end. I only made one hole ( it was bigger then pic, in folds), and with patience I was able to pull off the hooked end (using a bent flat head screwdriver) of the hose tastefully from the underneath. Attaching the new j-hose by using wd-40 as a lube, I slid on the hose from underneath then snaked it to my opening . It took me an hour and 1/2 for the total job. I cut my hole with tin snips, it was so quick and easy (drilled a starter hole). After I was through, I used exterior window tinned exterior tape on my hole. ( I cut it in folds, so I could re-close the hole tastefully).
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 672 times
- Been thanked: 163 times
Nice report to read. I've learned a new expression : pita, which I didn't know. I'm not also really sure to measure all stuff MVS brings to me ...
Congrats for the jobs well done Guys ! even If it's a bit frightening to see Gentlemen start to make holes in their Volvo...
Manov
Manov
- 13 Replies
- 6888 Views
Last post by VolvoBoron
- 1220 Views
Last post by Pop42
- 11 Replies
- 7880 Views
Last post by enotslim
- 6693 Views
Last post by pranayama
- 823 Views
Last post by deepsouth
