S90 Outside Temp -188F
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
cyberwolf
Year and Model: S90 1998 , V70 2002
Post by cyberwolf »
I recently picked up a '98 S90 and noticed that the outside temperature display is not working correctly. It displays -188 F all the time. I wasn't planning to bother with it, but I have read some things about other Volvo models reading the outside temp as part of the air conditioning circuit. The A/C is not working in this car and I'm about ready to start troubleshooting that.
Does anyone know if a low reading on the outside temp sensor will disable the A/C on the S90? Apparently will on some other models, but I haven't been able to determine exactly which ones.
2002 V70
1998 S90
2006 Chevy HHR
2002 Dodge 1500 Van
1998 S70 Totaled
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
cyberwolf wrote:'98 S90...outside temperature display is not working correctly..
S90 1997–1998 Ambient Air Temp Sensor ECT outside air sensor under front bumper $30.11
Volvo 760/940/960/S90 AC system diagnostic - Read notes there
Does your vehicle have this system: ECC climate control temp sensor measurements made easier?
If so, consider downloading this file.
cyberwolf
Post by cyberwolf »
Thanks for the info. I just ran the test and got the same 161 (solar sensor) code as the guy on the video. I'll have to take a look at the outside sensor when I have some daylight.
2002 V70
1998 S90
2006 Chevy HHR
2002 Dodge 1500 Van
1998 S70 Totaled
93Regina
Post by 93Regina »
cyberwolf wrote:I just ran the test ....
Keypoint - Always test a part, before buying a new one....
I'm into redblocks, not this newer equipment. I assume your setup is same/similar as in that cited literature. That PDF file has lots of information...
93Regina
Post by 93Regina »
Here's two more PDF information
Brief History
This file below might have more details on getting trouble codes...but maybe not...it appears Volvo ECC changed with time, with more codes...
xg14802.pdf
(357.02 KiB) Downloaded 284 times
93Regina
Post by 93Regina »
See this thread, S90, 1998, Flashing Blue AC Light, there might be a PDF to download.
Volvo ECC Electronic Climate Control Unit Removal, 850, S70, V70, XC70, V70R, S40, etc.
Climate control unit replacement, Volvo 960, S90, V90, etc
