I own a 97 850 and there is sound coming out of the right front dash speaker only. I have a little sound from the rest but not good at all. When i play with the fader on the radio it changes the sound a little. I took a speaker from my other volvo and that did not fix it. I also took the radio out of another 850 and that did not change anything so I presume I have wiring issues but how do I test the wiring. How many amps or volts or??? should I have at each speaker? What else should I test?
Thanks
Radio speakers not working
- Year and Model: Many Volvos
- Been thanked: 76 times
My guess is that you have an amp installed in the car and it is either bad or it possibly just blew a fuse. With an external amp the only speakers that work directly from the head unit are the dash tweeters. Depending on which head unit you have you can usually bypass the amp by swapping the connectors from the head unit to and from the amp. The connector that plugs into the amp will also plug directly into the headunit. The connectors to and from the amp are usually hidden in a gob of foam covered tape
There are some head units that have no internal amplifier at all, like the SC901, but most of the SC815 /SC816 units do have a decent size amplifier built in.
Check the fuses first though.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Are these fuses in the main fuse box or located somewhere in the external amp?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
I pulled up the schematic and the same fuse feeds both the headunit and the external amp so if the headunit is working then the amp is getting power - as long as it is factory.
- 701 Views
Last post by gagarin
- 4494 Views
Last post by Goupil
- 577 Views
Last post by kallekula
- 4125 Views
Last post by 850TurboTurtle
- 8579 Views
Last post by Stu70
