For Sale,
Bosch 628 ECU from 1996 850R which I ran in my 850 turbo. Price is 100 shipped USPS Priority. Open to trades for vintage speed parts, VDO cockpit clock, what have you? Pictures are available, pickup in Santa Rosa CA, if you want you can plug it in and see that it works. Email- jrenew at gmail dot com I have an ad up on IG too, @heybikey. Thank You!
forSale: 850 T-5 Bosch 628 T5R ECU
- dyn blin
- Year and Model: 1997 850 Wgn
- Been thanked: 2 times
Not far away from you in Bennett Valley!
Do you have a pic of the Bosch sticker so I may check the number? I don't think it''s compatible with my project car, but I'd still like to check.
Thanks
Thanks
'97 850 GLT Wagon- Driving to see 300k in the rearview
- dyn blin
Thanks for posting that so quickly.
Indeed, I don't think this will work for a tune in mine- I believe the M4.4 were only used in my '97 GLT and the '98 HPT's, although I welcome correction by the resources here if wrong.
GLWS. I'll watch for your aqua bug around town.
- Has thanked: 2652 times
- Been thanked: 1242 times
I run a 628 in my 97 T5 (HPT).
- Has thanked: 292 times
- Been thanked: 765 times
It will work, you can swap 4.4 and 4.3 ECUs among the 850s, there is no difference in the wiring harnesses the difference is entirely within the ECU. I run 4.4 in my 95 T5. But a 4.3 in a 97 will work like a 4.3, slower startup etc ... and the car's little 13g will not provide the boost that a 15g will, so I'm pretty sure the engine won't make the few HP difference that an R ECU provides at the very top end.
The main thing to look at for compatibility is emissions, whether or not your 97 has the same components as the donor 96. If not, there could be a CEL for SAS etc. And finally you can't just swap the 4.3 ECU into a 98 with 4.4, it will cook the AC compressor.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Thank you Erikv11!
yeah, the T5 turbo and the R turbo are different pieces.
Although, Using my finely calibrated pants-seat-dynomameter, the car did have a faster acceleration and increased likelihood of freeway onramp wheelspin. which was super rad. Also, the gauge pushed beyond the 50% mark, which despite having the CBV and the ipd tcv, +silicone hoses, it didn't do before.
formerly:
1996 850 Turbo Sedan
Yeah, when I made the 4.4 ECU for my 95 R, I gave up those extra horsies. Nothing refutes the butt dyno!
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Guys and Gals, I don't want to e-waste this thing, price dropping- $70 shipped, or best offer, or looking for a steel radio flyer wagon body, pre-1990, VDO clock? Weber 32-36 rebuild kit? BMW Bottlecaps 14"?
formerly:
