On the s60's I have owned in the past when I decelerate the instantaneous would go up sometimes like 80 mpg. It would make sense since my foot is not on the gas.
I am trying to diagnose a slight vibration in my steering wheel on idle. Its not the motor mounts (new). Its not the Maf (new). Don't have a vacuum leak no idle fluctuation. The LTF is a zero and the STF only fluctuates =-3% under load and idle,
What I do notice is when I decelerate the mpg goes lower rater than higher. I'm talking about 9 mpg. BTW my gas mileage is only 18mpg which is low. I am leaning towards a bad MAP but don't want to change part unless its bad. Is there a way with my scan tool to determine if the MAP is bad?
Madness
On deceleration instantanous mpg goes down
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
- Has thanked: 1613 times
- Been thanked: 4078 times
A bad MAP will usually pop a code. No code, hold off. My autel tool reports actual manifold pressure via the MAP (ME7 car) so I think a good code reader would sort that out.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Miles on it? When my front O2 went, I was getting horrible mpg in stop and go traffic and while waiting at a light I would see 99l/100km on the instant display - similar to 0mpg basically. Like a hole in the gas tank.
What brand are the new engine mounts/bushings?
volvomadness
mounts are oem. 145k. scan tool indicates 02 functioning no cel.
- oragex
Old worn out front O2 doesn't necessarily throw a code. Mine had no code as well, but was completely busted, with new sensor the mpg displayed normal values and fuel consumption got reasonable again. Not saying it's surely the O2, but it can be checked with a special voltage reader. On the other side, if the front O2 is original at 145K miles, it has fully lived it's life. I used NTK off Ebay and it's doing well (mine is the non turbo engine).
Is the engine shaking at idle? Might have to do with some misfire.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Front O2S is current-based, not voltage, can't really read it with multimeter without splitting the wire.
Front sensor in my wife's 02 V70 died this spring, it threw actual code. Car was a lazy dog for last couple of years, but no codes. 145k miles.
My 05 XC70 with 150k miles has 18MPG as well. I was thinking it is because of my driving habits, but then we've got a new XC60 with 5 cyl engine, which has both lot more weight and engine power, and yet better MPG. So I might change the O2S. On the other hand, XC70 pulls harder from the stop, while for XC60 it takes time to convince itself it's time to kick in. Then it pulls like train.
- 41 Replies
- 6751 Views
Last post by Seaway
- 68 Replies
- 11505 Views
Last post by 1ezliving4ume
- 28 Replies
- 3968 Views
Last post by RickHaleParker
- 11 Replies
- 2274 Views
Last post by wizechatmgr
- 1042 Views
Last post by Oka
