Defeating the torque limit request on the Volvo 850 Turbo
Defeating the torque limit request on the Volvo 850 Turbo - TCM Signals
Beefsquasher
- Year and Model: 1996 850 T5
So what I'm gathering from reading this thread is that cutting the wire does nothing, and you must apply somewhere around Ubat to keep the ecu from limiting torque?
- Has thanked: 2864 times
- Been thanked: 1332 times
True.Beefsquasher wrote:So what I'm gathering from reading this thread is that cutting the wire does nothing,
Don't know.Beefsquasher wrote:and you must apply somewhere around Ubat to keep the ecu from limiting torque?
Beefsquasher
I will try it and report back this weekend.
As long as I've owned my volvo I've kept looking into this thread for information, and everytime I do someone says they'll report in a timely manner.
I believe I've seen a successful implementation of this on another volvo community. Has anyone else seen one? I know Jimmy57 claims success but no one can replicate his results.
tightmopedman9
- Year and Model: 1996 855t
Wow I'm surprised you guys are putting so much thought and effort into this whole thing, even cutting up your ECU harness! You can simply grab a M4.4 ECU (from a 97.5-98 S70, V70, C70 or 850) and program the boost limit and ignition retard by shift as you like.
Check out the thread I created on VS, 'Tuners Rejoice! Free Tuning For M4.4!'. The thread is pretty long but if you follow the Wikia link you should get a general idea of what is going on.
With just a simple VAG-COM cable, a M4.4 ECU and a 13.5V+ power supply you can modify any ECU parameter you'd ever want to, and more!
There is a 'Vehicle Speed threshold for boost reduction on gearbox signal' value that from the factory is set to 10km/hr. Set this to 0 and you'll be burning tires all day.
The other relevant map is 'timing retard on automatic transmission gear shift'. This is a map that specifies the amount of timing retard, at a given RPM, when shifting. You could reduce this map, but I would recommend being wary off too little ignition retard, it might shorted the life of your transmission.
- 2396 Views
Last post by waffleshill
- 3974 Views
Last post by Integrexman
- 3988 Views
Last post by goldmandan
- 18 Replies
- 9883 Views
Last post by Orchid70
- 1121 Views
Last post by cn90
