How to fix "Bulb failure position light" Topic is solved
JNavas
Year and Model: 2008 S60 2.5T
Been thanked: 4 times
Post by JNavas »
"Position Light" is Volvo-speak for Parking/Tail Lights, and the message usually means either bad bulb or bad bulb connection.
The best way to deal with the problem is to replace all bulbs in the rear of the vehicle, which is easy.
(When one bulb goes out, others probably won't be far behind.) When replacing bulbs:
  1. Check the bulb sockets, and if there is any visible corrosion, clean them with spray electronic cleaner (and then dry them).
  2. Coat bulb contacts with a film of bulb dielectric grease, which will help keep them free of corrosion and ensure good connections.
Important: There is considerable confusion and misinformation on proper bulb types (even from major manufacturers and suppliers*). Your best bet is to check the owner's manual for proper bulb types or get them from a Volvo dealer. Use only Euro spec bulbs, not USA spec bulbs.
Good resource: Volvo Bulb Guide and Cross-Reference
* For example, IPD lists the rear Tail Lights and Marker Lights for the P2 S60 2001-2009 as 10W. Correct wattage for the 2008 S60 is 5W (Sylvania 5007). Sylvania lists the Side Marker Light Bulb Rear as 7528, but they are also 5007. etc. etc.
Hope that helps,
John
2008 Volvo S60 2.5T (black with oak interior)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2865 times
Been thanked: 1332 times
Post by matthew1 »
Beautiful.
Also -> Amazon link
lcruz1725
Year and Model: 2006
Post by lcruz1725 »
I have change the light bulbs on the rear passenger side but image tail lights don't work. Checked the fuses, and nothing. The rear driver side has no problem. And I still get the message on my dashboard. By the way it's an 06 Volvo s60
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
nice thanks
I've also heard to get the right wattage for each rear bulb
in three years I've only had to replace a short beam front bulb
JNavas
Post by JNavas »
lcruz1725 wrote:I have change the light bulbs on the rear passenger side but image tail lights don't work. Checked the fuses, and nothing. The rear driver side has no problem. And I still get the message on my dashboard. By the way it's an 06 Volvo S60
  1. Make sure to use correct bulb type (Euro spec) and wattage. Check Owners Manual.
  2. Clean contact areas with electronic cleaner.
  3. Use a thin film of dielectric grease.
Hope that helps,
John
