2001 XC70 - Pumping out fuel tank
Has thanked: 1613 times
Been thanked: 4078 times
DPDISXR4Ti wrote:
JRL wrote:Changing the subject. You either have or had an XR4Ti Merkur?
Only one? I've had a few. Most recent project turned one into a Ute. Search "Project XRBrati" for pics if you're interested.
Back on topic...
Cut the fuel line at the fuel rail, attached a hose to a gas tank. Found the fuel pump access panel under the rear seat (driver side) and snipped the blue and black wires. Using a 14.2 volt Ryobi battery, I powered the pump directly and out came the fuel. I think I've got about 12 gallons out so far, before it started sputtering.
The owner indicates that he had just filled it up before it died, so it seems there should be more fuel in it. So I'm wondering if there's any magic that needs to happen to get the fuel over from the other side of the saddle tank. Is there some sort of cross-over tube?
There's an ejector pump that brings the fuel from the saddle to the main pump, so you should have gotten most of it out your way. How long did it take, I'm curious..
