Rate your skills - the official MVS poll
I am a (blank) Mechanic
Poll ended at 14 Sep 2016, 16:46
O Rivers - I can't even pump my own gas (with apologies to NJ residents)
1
1%
1 River or Beginner - I can perform monthly checks of dipstick, coolant level, PS level
1
1%
2 Rivers - Basic - I can do an oil change, Change a tire, wiper blade, fuse, relay, lights
5
6%
3 Rivers - Mechanic I can do a full brake job, driveshaft, PCV, fuel pump
45
57%
4 Rivers - Advanced - Top end of motor, bottom end of motor, drivetrain - can often find better ways to do things than 'the book'
25
32%
5 Rivers - Expert - You know who you are. The few, the proud - mike, jimmy....and less than 10 others..and not me.
2
3%
Total votes: 79
mecheng
Has thanked: 15 times
Been thanked: 21 times
Re: Rate your skills - the official MVS poll
Post by mecheng »
Some of the basic things, like changing oil cooler lines should rate as 3, but on Volvo's I would rate them as 4 because there is little to no room for anything. What an awful job, just finished.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
paredown
Year and Model: 1999 V70
Post by paredown »
I put myself at 3, but in reality I'm probably a 2.5.
My father was a great mechanic, and I was the 'gopher'--so I have good reflexes and a general understanding of how stuff works. But I don't have his seemingly infinite reservoirs of patience, and I have proved many times that I have a tendency to think things through to about the 90% level and fly at it--and sometimes pay for my impatience.
The contributors here have saved my bacon many times--and have encouraged me to 'boldly go' where at least I have not gone before, so a big thanks to everyone here.
1999 na 2.4l V70 beater--donated to Habitat in running condition
Has thanked: 1836 times
Been thanked: 1709 times
It depends on the age of the Volvo. After over 40 years wrenching on them I was at one point a 5 on the 120/140/240 ranges, and even stripped and rebuilt a 760 Turbo motor. I'll have a go at most things, but my limitations is the correct tools and facilities to do the work.
On the P80's (850-S/V70) I will tackle most things but this is where tools and facilities become the issue. Do I spend a fortune on tools I may use once every 10 years or just pay someone else to do it.
Overall, maybe a 4 on the scale?
Has thanked: 1498 times
Been thanked: 3810 times
It's an automatic 5 for figuring out how to replace the crank pulley correctly
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 28 times
Post by cuhfs »
C70 Engine top end and replaced a C70 transmission and a V70 clutch once... along with the #3 items listed... so perhaps a 3 or a lightweight 4. Thinking that the test should really be like a road rally... time - speed - distance - and accuracy. Took over a month to do the top end and a long time for the transmission too - so minus points. As with a road rally - good equipment and a co-pilot would be a great help. Never had to re-do job.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
abscate wrote:
tryingbe wrote:I've know a lot, and there are a lot more I don't know.
So, abstention for me.
Here's one of the 5s.... :D
Nope. Just someone who can takes things apart and put it back by memory, still use the book for torque specs though. I also happen to be not afraid of the computer side of things.
I am currently working on adjusting the mpg gauge in the M4.3 ECU coding since I've change to blue injectors and my mpg gauge is way off. Will post what I found when I have it all complete.
85 GLH, 367 whp
00 Insight, 72 mpg
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1240 times
Post by matthew1 »
Warning: I took a statistics class decades ago in college. :shock:
Problem
Why no low-skill 0 or 1 votes? Are we really all universally middle-technical here?
Theory
The bell curve is accurate generally (the shape checks out), but there are problems with the edge distribution of votes.
  • all the Level 2 and 3 votes -- it's people most likely to vote*
  • low Level votes are people who take their cars to the dealer and Jiffy Lube
  • high level votes are low because hey, we're modest, we drive Volvos ;-)
* this site draws people like us -- users who are likely to go out on the Web and search for how to DIY
Also -> Amazon link
dosbricks
Post by dosbricks »
j-dawg wrote: I have never messed a job up so badly that I broke something critical or had to do the job again, but the cost is that I work extremely slowly. It takes me days to do work that would take most people hours. I obsess and fret, checking everything repeatedly....
I can completely relate to this. As I've aged it takes me twice as long as it used to to do a brake job. But still proud to associate with the champions on MVS who have walked me through a few tight spots!
I'm taking longer to DIY stuff because I take my Dremel to everything in a job and bring it back up shiny metal, lubricate and restore to Stockholm/Brissels condition.
No shop will do this for you
98v70dad
Year and Model: 98 V70
Post by 98v70dad »
I'm definitely more than a 3 and less than a 4. There's a lot of territory between 3 and 4.
