MVS-Amazon link helps MVS!
2004 S80 T6 Ice White
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
June
Year and Model: 2004 S80 T6
Has thanked: 370 times
Been thanked: 185 times
Post by June »
Up until this year my car has never had a repair. Just routine maintenance, 3000 miles per oil change (synthetic only ), break shoes once, and it's 3rd set of tires, and 2 batteries, oh and replacement radiator cap immediately upon delivery to me. Since the 1998 V70 GT and all it's nightmare cooling system leaks which my dealer mechanic put a black cap for a 1990 240 that stopped all the problems. So both Volvos since I threw the green cap away and replaced it with a new black one from the parts department. All repairs have been performed by a dealer service department only. I am taking time to put this up as no T6 S80 cars seem to be listed in this section. Now I made the decision to put the repairs needed earlier this year when I hit 110,xxx and it was time for the timing belt service, and all at once the two outer axle boots cracked, and suspension rubber parts were standing to show cracking making a $5000.00 repair needed. I just don't want to drive anything but a twin charge 6 cylinder T6 Volvo. I had a 2002 S80 T6 which I rolled into a field and both me and the dog stepped out without a scratch, and it's replacement which is the 2004. That brings us to this year and I will list each ticket separate as I have done a lot of maintenance so far this year and will post everything here on out.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
June
Re: 2004 S80 T6 Ice White
Post by June »
March 14, 2016 109,293 miles
Line 1
10k service
CF5 fuel enhancer
ADV Formula MOA
5w30 Castrol Edge
Oil filter INS
Gasket
Line 2
Timing belt water pump ECT
Tooth belt kit
Coolant pump kit
Thermostat housing
Gasket
Bleeder hose
Antifreeze
Belt
Hose clamp
Line 3
36 General repair concerns
1 36050999 Control Arm
1 36051001 Control Arm
2 31212191 Roller
4-wheel alignment
1 989763 bulb
35 CVR ? I don't know what this is
A/C service (per my request to replace freon)
Line 4
Replace both axles
1 8251782 Axle shaft
1 8251781 Axle shaft
Grand total $4,651.59
My Volvo cars owned
1996 960 ordered
June
Post by June »
April 5, 2016 110,209 miles
Took it in as acceleration was not smooth on harder acceleration.
Shop determined bad turbo control valve was faulty and a break vacuum valve had popped off hose apparently due to high temperature under the hood. Also 6 clips had popped off of the front bumper due to a high parking stop.
1 31400692 switch
6 3541113 clip
1 30670448 Solenoid valve
Total $445.87
My Volvo cars owned
1996 960 ordered
June
Post by June »
April 15, 2016 111,412 miles
Took it in for the washer sprayers on the hood, one had popped up and a oil change. Also material covering the sunshade had started to fall. My mechanic noticed that the fuel door hinge had a crack.
Line 1
3 30655605 washer nozzle 15.77 total parts47.31
Labor 64.75
Line 2
1 31265160 hinge 20.69
Labor 38.85
Line 3
BG cleaning oil change.
1 205 fuel enhancer 9.95
1 115 ADV Formula MOA 9.95
1 1275810 oil filter 12.00
1 977751 gasket 1.00
Labor 60.65
1 530su6 Castrol Edge 5w30 43.30
Line 4
1 989829 bulb 27.30
2 968458 flange cap nut 2.87 total 5.74
Total bill $381.00
My Volvo cars owned
1996 960 ordered
June
Post by June »
April 26, 2016 111,612
Took car in for replacement moonroof sunshade which was ordered at previous ticket
Line 1
1 39850620 Cover plate 622.48
Labor 194.24
Shop fee 23.95
Total bill 899.51
My Volvo cars owned
1996 960 ordered
June
Post by June »
April 27, 2016
Took in for new moonroof side pieces and a/c blowing slow.
Needed filter
1 708 Frigie-fresh 8.98
1 3060752 pollen filter
Labor 64.75
Line 2
2 8643242 Modesty Panel 28.89 total 57.78
Total bill $188.29
My Volvo cars owned
1996 960 ordered
June
Post by June »
May 3, 2016 111,875
After endless battle with Volvo over the On Call which has been not supported forever, really upsetting me. Much worse has been the endless messages on dash to renew subscription. Yes Volvo sold me a option that they should have upgraded the equipment in my opinion, but I finally got someone at Volvo USA to send my dealer info to stop messages. I argued forever over this problem.
Line 1
Remove On Call
1 8651312 VOC Remove 30.22
Labor 64.75
Line 2
Battery died in mechanic stall
1 30772231 Battery 217.85
Disposal fee 1.50
Labor 70.00
Total bill $369.34
My Volvo cars owned
1996 960 ordered
June
Post by June »
May 31, 2016 113,487
Car started making a click noise shifting from reverse to drive.
Line 1
Repair axle ping remove and loctite both axles
Labor 139.49
Shop charge 12.55
Total $162.68
Before leaving I thought about the windshield wiper needed replacement
1 31301437 Wiper Bl 1018D 65.75
Total $61.17
My Volvo cars owned
1996 960 ordered
June
Post by June »
While in Tampa visiting car started leaking oil so I had it repaired at Tampa Volvo. I don't have this ticket as I had it put in my file at Osteen Volvo for future warranty on replaced seals.
Rear cam seals replaced and oil change
Bill was around $450.00
My Volvo cars owned
1996 960 ordered
June
Post by June »
Also during the trip to Tampa my sisters indi mechanic wrecked her transmission in her 2005 S80 T6 by using multiple vehicle atf +4 it died driving home from service. To prove a point I watched him every second while he preformed the same fluid and filter change only I brought the fluid. Walmart brand was all I could find clearly marked Dextron III plus Volvo filter kit. My transmission still had the factory fill. I didn't have Tampa Volvo flush it when they fixed the cam seals but I drove it straight to Osteen Volvo which is the next ticket to be sure the correct Volvo fluid went back in.
That indi plus fluid+filter I bought was about $250.00
I did see the pan interior plus magnet the moment it came off and it was clean at 12 years and 112,xxx miles.
My Volvo cars owned
1996 960 ordered
