Transmission Fluid Update Topic is solved
charleskennedy23
Year and Model: 1998 V70 T5
Post by charleskennedy23 »
9,000 miles ago I did a transmission fluid exchange in my 98 v70 T5. To perform this maintenance I did the three drain and fills over the course of three weeks. I used valvoline Maxlife Dex/merc full synthetic. My plan moving forward is to do a drain and fill every 9-10k to keep the fluid fresh. I took a picture of the drained fluid in a glass jar next to a pict of new fluid in a glass jar so you guys could see what it looked like. I thought it looked a bit dirtier than I expected but the color of the dip stick looked bright red. Any thoughts?
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
charleskennedy23
Here's the pic of drained fluid and fresh fluid
Fresh fluid on left / drained fluid on right
Charles Kennedy
Has thanked: 292 times
Been thanked: 765 times
I agree that the flush is not yet complete. But getting there!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
dyn blin
Year and Model: 1997 850 Wgn
Post by dyn blin »
When we picked up our current daily driver at 170k miles a decade ago (the P80 in my signature), I suspected the fluid had never been changed and did the same thing (3 drain and fills) . When I checked at 5K miles later, it was again discolored. As a result, I started a drain and fill when I have the car up for an OCI. It may be overkill, but it's not terribly expensive if you source the fluid in gallon units at Wal-mart (I use the same Valvoline Maxlife), and we've been able to keep the original transmission (we're at 265k miles).
We've done the same thing on the "project car" P80 starting at 110k, and 25k+ later the transmission that I feared was knackered has become progressively smoother. I believe that puts us at 2 full fluid swaps on her-I'll try to trade the extra $60 in fluids for another year's delay on a transmission swap as long as she'll let me.
'97 850 GLT Wagon- Driving to see 300k in the rearview
Covert
Post by Covert »
Manual says to replace with dexron iie is there an alternative that is suitable ?
I use cheap, Dex III for all of my P80 cars. Supertech brand over here in the US.
'06 S60 R, 197k
dorvin
Year and Model: 1997 Volvo 850 T-5
Been thanked: 4 times
Post by dorvin »
I'm beginning to think I should do the same maintenance with my car. I've put on about 30,000 miles since I did a three part flush @ 150k
30k is the interval between flushes I subscribe to, either that or the 3.5 quart drain and fill every 10k.
'06 S60 R, 197k
Has thanked: 1850 times
Been thanked: 1712 times
I did a drain and fill when I changed the axles a couple of weeks ago. Dam thing nearly drained 5 litres out as that is what it to refill near enough. After only 100km, I can see the oil is already darker than after the fill. I will try to do 1 more flush and fill before heading to California in a couple of weeks.
Other than being a pains, and the danger of stripping or damaging the trans drain threads, I don't think you can drain and fill too often. Erik's suggestion of a drain and fill ever 10k miles sounds reasonable.
Remember you are only removing maybe half the trans oil in a drain and flush so it could take many flushes to get it cleaner. That is why they suggest the flush method a you use about 12 liters, but by then the fluid is flushed through all the parts of the trans so it looks cleaner.
Covert
Post by Covert »
I have no time or mileage if this has been done on my car so I think it's a must . If you take the drain out. how much fluid comes out in litres ? Don't want to not have enough to go back in !
