2011' C30 running lean under boost
TheScott
Year and Model: 11' C30
Post by TheScott »
Hey guys!
The other day I had my car dyno'd and the car made the numbers as rated, if not better. But one thing we all saw as concerning was it's AFR. under boost, it held 14.7 AFR till redline. Generally, I thought turbo cars, these in special, should be around 11-12AFR under boost. Please correct me if I'm wrong but should I be concerned? The car is getting the Polestar update done to it on the 29th.
Best,
Scott
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
It's not running lean. It's right on the money.
14.7 is the stoichiometric ratio, the only AFR where all of the fuel and all of the air will be consumed. Any other ratio, and you will have leftover one or the other.
I would expect a modern engine to fight to maintain 14.7 like the hounds of hell were on its heels.
Historically, going rich under boost was a knock-prevention measure; literally wasting gas as a liquid in-cylinder coolant that's not intended to burn.
5 others that came and went
