940 turbo juddering when slowing down
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
the doc
Year and Model:
Post by the doc »
i have this problem with my 940 1993 iv changed the brake discs and its still the same its not a violent judder more like a surge and ive noticed that the gear lever (auto) is moving back and forth in time to the judder any clues what it might be?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
As you say you have changed the discs (rotors) I assume that this judder is whilst you are braking.
Do you feel the judder when slowing down without using the brakes?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
the doc
Year and Model:
Post by the doc »
no its only when braking i dont feel it through the steering or brake pedal but more through the whole car i was wondering if it could be a engine or gearbox mounting as the gear lever moves in time with the judder?
billofdurham
Check the engine and transmission mountings. Also check the propeller shaft centre bearing and mounting. This has caused problems on 940s by allowing the prop shaft to move up, down and sideways.
Bill.
Previously:
