This is going to sound harsh, but it's for the benefit of diagnosing the car. It is not a personal attack.lapederson6 wrote:Fuel pump runs, compression is fine, spark and fuel are fine. Mechanically everything checks out. And not only did we test everything, but we had two mechanics check it out and test everything. We are truly stumped.
What is the ect? Not sure what you were referring to.
I should have been more specific but when I asked for result, I want actual numbers. Fine is not an acceptable answer. When you ask a woman for her number, would you take "fine"? Of course not.
So, let's try again.
What are the compression test numbers?
What is the fuel pressure number at the fuel rail when someone is cranking the engine?
Did you see actual spark coming out of the spark plug?
