Volvo 850 Transmission Solenoid Replacement DIY
This topic is in the MVS Volvo Repair Database » Volvo 850 Transmission Solenoid Replacement DIY
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
In my case the car would drive fine until the transmission got warm. If I was lucky enough to be on the high way and just cruising everything was fine. But if I got stuck in traffic where a lot of shifting was required it would soon go into limp mode. The real indicator was reading the codes though.
ronhall102
Year and Model: 95 GLT 850
Post by ronhall102 »
Thanks a lot now I can do this on Monday early.
you are the best. so much you made me save.
Bless you. may the Gods smile on you.
everwiser
Year and Model: 1998 V70 X/C
Post by everwiser »
Thank you for your write up and the tips on doing this without dropping the subframe. I have a '98 V70 X/C and a P0740 code for the lock-up solenoid. I checked the resistances of all my solenoids this past weekend hoping I had a wire issue instead of a bad solenoid. No such luck. The lock-up solenoid measured 160 ohms no matter which way I manipulated the wiring. I also have one of the other shift solenoids (S2 if I remember right) that was reading just over 15 ohms while the other was about 12 ohms. Since I'm going to have to "go in" anyway, I figure I will replace S1, S2, and the lock-up solenoids. Being I have a '98, does anyone know if the numbers listed at the beginning write up apply to my car? Also, thanks for the tips/link to Trans Parts; awesome prices. Thanks in advance for any info!
polskamafia mjl
Try emailing them and see what they say. They were pretty helpful when I talked to them.
Has thanked: 1613 times
Been thanked: 4077 times
Bumping this great thread to discuss gasket solutions
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Wow this is a Great thread. The gasket problem makes me wonder if I could just put that material through a laser cutter.
