Difference in struts between 2002 and 2009
keaunym
- Year and Model: 2009 Volvo S60 2.5T
I had a 2002 2.4TAWD with ~130,000 miles back around 2008 that had stiff struts and a nice tight ride. As far as I could tell those struts were original. My new used 2009 2.5T that only has 83,000 miles has front and rear struts that bounce like an old mattress. I was told by a mechanic the suspension was changed between these years and that supposedly this is an improvement. Is this correct and is this how the new struts are intended to perform? Can anyone confirm that the newer S60 struts have considerably more bounce than the older ones?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Maybe previous owner replaced the struts with some cheap brand. here's some options
https://www.fcpeuro.com/products?keywor ... quickstrut
- oragex
I have read somewhere that Volvo upgraded at some point the suspension to be somehow stiffer, perhaps the struts they used do wear in the manner you are describing. On older models, when the struts would wear, they would become stiffer and the car would still be very stable, just harsher on poor roads.
JRL
- Year and Model: Several
- Been thanked: 16 times
2007 but I read sway bars and bushings were changed. Nothing was ever mentioned about different shocks and struts
- June
- Has thanked: 523 times
- Been thanked: 261 times
Your 2002 was AWD and I assume that the 2009 is not. Back in 1998 when I bought the V70 GT I tested the cross country version (AWD ) which drive completely different than the GT FWD. The FWD GT was lower and slightly softer. Both were brand new cars, but drove completely different. I think both had the same turbo 5 cylinder. I bought the FWD for the better ride and the engine accelerated better I thought at the time.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- oragex
JRL wrote:2007 but I read sway bars and bushings were changed. Nothing was ever mentioned about different shocks and struts
Correct, I've misread this page thinking it was the shocks that were upgraded https://www.nadaguides.com/Cars/2007/Volvo/S60
- 31 Replies
- 29143 Views
Last post by Bodhi5
- 827 Views
Last post by Florida Wheel
- 1313 Views
Last post by mrbrian200
- 879 Views
Last post by sergitin32
- 3303 Views
Last post by Legofan
