We are selling the old 1998 S70 and just as I am taking the check the CEL come on. My Code reader says P0447. I erased all code and withing 10 sec it comes back. The SAS sytem is all good with new air pump and functioning valve. No bad wires. Ive checked the evap valve on the fan shroud teted good. Wire to ECU good. I cant find a system diagram to find any other purge valve. Can anyone hlp with Code P0447?
Thanks
Problem Code P0447 Cant find problem
That's probably a wiring fault in the purge of canister shutoff valve
The system is covered pretty well in the VRD
mosherman1
- Year and Model: 1998 s70
What is a VRD?
I have voltage to the canister purge valve. (fan shroud) Is there another purge valve in the system? Maybe near the fuel tank?
- Has thanked: 311 times
- Been thanked: 817 times
Yeah, we should have a policy about using acronyms without defining them (;) - pardon me mosherman1, that's an inside joke).
VRD is Volvo Repair Database https://www.matthewsvolvosite.com/volvo- ... abase-home.
mosherman1
ok All valves are working Purge, Shut off and SAS. Here's the problem They all be the same voltage of just under 7V. I think they need 12v and ideas? All Wires are good.
You need to fault trace and find the voltage loss. The supply should be at battery voltage
- 820 Views
Last post by volvo240student
- 1162 Views
Last post by rspi
- 611 Views
Last post by havardbo
- 13 Replies
- 3735 Views
- 966 Views
Last post by kuuze
