External temp sensor question?
Has thanked: 2207 times
Been thanked: 1852 times
On my 2000 'R' occasionally I get what looks like a message of 'dISC' when it is left in the external temperature setting. Turning it to a different setting or restarting the car will normally have the message return to normal. Any ideas? I probably have other external temp sensors kicking around in the garage to swap in if that is the issue.
Thanks,
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
As far as I know, it's actually the switch itself that's gummed up. I had that happen to me a lot when I first got my car. I rotated it back and forth quickly like 50 times and I haven't seen it in years.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Good to know, I'll try that when it happens again. Thanks!
Has thanked: 1611 times
Been thanked: 4071 times
Check your CD player
I harvested the entire dash on the 99 so I have a used switch if needed
Ok, are you pulling my leg? I'm talking about the LCD display on the speedo housing and not the display on the head unit?!
I've been known to pull a leg or two..
I wonder what dISC means on the speedo display?
I'm only guessing, but 'dISConnected'?
We covered this in 2008
Indeed, it is a marker that the DIM is not talking to the ECU
https://www.matthewsvolvosite.com/forums ... hp?t=15161
