If you don't know what this means, don't worry about it, it won't affect your life in any way. Or read about it here. In short, it encrypts your communication with MVS.
You may or may not see a lock icon in your browser when you connect. If you don't, don't worry, it's still working as long as your URL has an "s" after "http"...
The difference is the "s" after the "http". That means "secure". When you log in, use this ucp.php?mode=login and your username and password will be encrypted.
If You Don't See a Green Lock Icon
There are different types of encryption, and as far as I know, they're all strong (if you're using a modern browser), the difference is in the certificate my server operates under. It's a general-purpose certificate, not a dedicated one. Like I said, I don't think the encryption strength is any less than any other HTTPS connection, only that I haven't jumped through the hoops to get a dedicated certificate. MVS runs under a Cloudflare certificate.
I've got some further testing/fixing to do, and if you want to help, reply to this topic with the bug report.
Known problems
Internal redirects falling out of HTTPS to HTTP
example:
- log in
- go to https://www.matthewsvolvosite.com/
- in upper right navigation, click on Forums -> Log in / Register
result:
- browser falls out of HTTPS, lands at https://www.matthewsvolvosite.com/forums/index.php
If you want to help, use that same format above in red to list bugs you find.
Moving forward
After a week or two of you guys testing this and me fixing what we find, I'll instruct the MVS server to enforce HTTPS on all urls.
Currently, you have to be vigilant to see if your browser is falling out of HTTPS while you click around.
Questions? Comments? Leave them below.
