WTB: V70 load area RH panels in beige
Has thanked: 1850 times
Been thanked: 1712 times
I am having difficulty finding good beige panels for the RH side of the load area that surround the RH rear window. The upper one covers the tailgate gas struts, and also has the speaker cover for the rear pillar. The lower one is the one around the lower part of the RH side window and has the carpet attached to it. The PO of my 2000 V70 NA SE base has managed to break the rear edge of both panels including the cut-out for the load cover to lock into.
I'm looking for un-cracked panels in ideally clean condition. I don't need the carpet portion on the lower panel as it will be cheaper to ship to me in Calgary Canada. Again it would be perfect if the lower panel has the 2 holes for mounting the load cover just behind the rear seat seat-belt. If not that is OK as I can drill them out, panel condition is more important.
Let me know what you have and what you would like for them.
Thanks,
I have been asked to clarify what panels I needed so pictures of offending items attached below will hopefully help:
Ends of broken panels RHS cargo area
Ends of broken panels RHS cargo area (2)
Lower RHS cargo panel with carpet attached
The lower panel has 1 plastic clip that will likely break, just as long as the holder is good. You need to remove the joining piece by the rear seat belt that prises out and there is a Torx screw into a metal bracket that needs removed. I can't recall if there is anything needed to be removed from the lower front edge.
Upper and lower panels
The upper panel is held in place by some clips along the top that snap in, and one torx screw toward the back of the hook shown above. On the edge by the door there are 3 (?) metal spring clips that pull out, and a few pop in clips on the LHS of the speaker. You then have to carefully remove it from the lower panel rear edge and the roof panel it will slide out from, but there is about an 1" of overlap.
Cargo area
Cargo area
Hope this helps.
Thanks,
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 28 times
Post by cuhfs »
Will a 96 850 wagon part fit?
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Check your pms.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
billy780
Year and Model: 2004 XC70
Post by billy780 »
How do those look?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
They were made in 3 different tans
Thanks JRL for your wise input as always.
These look the same as my car as in the first picture you can see the darker lower tailgate surround as per my V70.
billy, can you confirm you have been getting the PM messages I have been sending you on the subject?
Many thanks to all replies.
Oh, on the 850's panels, I am not sure if they are the same color as per JRL's input. They fit the same but the color I just don't know. I know the beige 98-00 V70's have all looked the same when they have that 2 tone at the rear with the darker lower section.
Billy are you out there? Still don't know if you are getting my PM messages? Appreciate if you can get back to me on the panels as I am still interested.
Thanks,
Has thanked: 1505 times
Been thanked: 3818 times
Just check your outbox Neil...if the recipient has read it, it will no longer be in the outbox. If S/he has not, it will be sitting there still.
Thanks for clarifying the PM system for me. Wondered why sometimes there were messages still showing in Outbox, and now I know!
Appreciate the help.
