Hi everyone, I am thinking about removing the rear console cigarette lighter / 12v jack from the console and relocating it up to the front of the dash area to power an accessory. Here are my questions:
1. What direction is this wiring run? I assume it runs front to back, and that I could simply remove it from the console, plug the hole and relocate it. My end goal is to have it near the glove box if possible.
2. Fusing: is this power jack fused with the other 12v jack in the front of the console or separately?
I hardly ever have anyone in the rear seats and even if they did they don't need a power jack. And they certainly don't need a cigarette lighter...
Re-routing 12v rear power jack / cigarette lighter
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Why not use the thoughtfully provided accessory
power connector that's already there in your dash?
search.php?keywords=accessory+connector&fid%5B0%5D=1
- Been thanked: 4071 times
I pulled a console from a 99 recently and will see if I can discover wiring. I think it is front to back, with 99 % certainty.
- SonicAdventure
I thought about that, but the CB I am going to use is already wired with a 12v socket plug, and rather than cut it off and hardwire it. If I was running something without the plug I would use the accessory adapter.BEJinFbk wrote:Why not use the thoughtfully provided accessory
I was actually at the junkyard this morning and I kind of answered my own question by looking at a console that was torn out of a 1999 S70. The rear 12v socket is wired front to back and can def. be rerouted further up.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
I did something similar, but I tapped into the 12 volt power lines on the radio harness. Completely reversible, and the rear cig lighter still works.
viewtopic.php?t=68508
- 1402 Views
Last post by Joffwillson
- 12 Replies
- 1576 Views
Last post by Krons
- 821 Views
Last post by swedet17
- 2970 Views
Last post by 93SCMax
- 2581 Views
Last post by alschnertz
