Another solution, used all the time to bypass
https://www.amazon.com/Universal-Immobi ... ass+module
Transponder in key is shot. No funds for new key. Must bypass Topic is solved
- Has thanked: 1505 times
- Been thanked: 3818 times
I think we have had several unsuccessful install attempts with kit like that on Volvo, especially 1999+
JRL
- Year and Model: Several
- Been thanked: 16 times
You all realize this is from last Sept, and the OP by now has found a way to start his car but never bothered to come back and tell us what he did!
Op probably never got it running. He didn't have tow money, so owning an old Volvo was probably not a good path in retrospect
Who buys a car without functioning keys,?????? That's one step below upside down intercoolers...
before you attempt anything you have to get the alarm to turn off. I would try to lock and unlock the car from the driver door at least three times. as for starting the key and transponder are matched. put the junkyard immobilizer ring on the ignition and push the junkyard key up against the antenna ring. Use your regular key to start the car.
- Year and Model: Lots
- Been thanked: 128 times
I bought some ID48 transponders from a local locksmith recently.
Henry (doublebug) was the guy who re-created new immobilser codes in a 2006 XC70 that had lost them from the CEM and then programmed the transponders to suit. That's what I call magic!!
Mind that this is doable on the later style CEMs. I don't think Henry can do this with earlier ones or can you, mate?
doublebug
- Year and Model: XC90 2007 D5
- Been thanked: 7 times
I can but for 1999-2004 CEMs corruption goes in some unpredictable way so in some cases some additional magic is required
Sometimes even external chip programmer help needed.
If you have questions about Volvo firmware ask me. I may know an answer
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
Simple point.jenkinskg wrote:please educate me on hardware used, I need to add remote to my car
You need to buy NEW or REMANUFACTURED remote and go to official dealer, or call to service, which can to program this thing.
A little bit about REMANUFACTURED remote control:
item should be together with BARCODE!
Some sellers like to call remanufactured remote with new package only, but there is not reseted chip inside. You need to be careful, if you want to buy remanufactured remote control.
Volvo electronic expert
Online Data Transferring Service for Volvo modules
