19" pegasus on v70
thomas larsen
Year and Model: volvo v70
Post by thomas larsen »
I have looked on the 19" pegasus wheels to my 2006 volvo v70, the new wheels have a offset of 38 and 8" wide.. can i run them with no problem on my v70??
8x19
offset 38
tire 235/35 r19
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
From forum readings, good chances of tire rubbing, at least when turning. The car will ride more harsh is the streets aren't smooth
thomas larsen
how about the offset, is that alright???
oragex
Post by oragex »
I suggest remove one of the wheels on the car and read the offset and dimension stamped somewhere inside. If the offset is positive, you may want to get similar or smaller offset. It is best to do it this way because wheels are varied and you must clear the front calipers.
thomas larsen
got the wheels on the car, just need to lowering the car now
thomas larsen
What lowering suspension should i go for, i have looked on 40mm, how about the Shock Absorber, should i change them too???
